Question about Canon Office Equipment & Supplies
Canon printer colours (i9950) have recently deteriorated despite cleaning
  • Unclebern Aug 21, 2008
    I have done the obvious and replaced all eight cartridges with no success
  • Canon Master
  • 19,396 Answers
On this printer you need to replace the printheads after a while.
Posted on Aug 21, 2008
  • Ginko
    Ginko Aug 21, 2008
    "QY6-0055-000 Printhead
    The i9950 printer uses a QY6-0055-000
    Canon Printhead. Printheads are classified as spare parts and as such
    do not need to be replaced as often as the ink tanks inside the
    printer. Over a period of time the resistors in the printhead fail and
    the image quality deteriotes.
    When should you replace the printhead?
    The printhead does not need to be replaced each time the ink cartridges
    are replaced, only when print quality deteriotes and a head cleaning
    fails to resolves the problem, we suggest checking with Canon if you
    are unsure."
    from
    Canon Printheads i9950
    Just order and replace printhead from website above .
  • 928 Answers
When you say deteriorated do you mean that the colors are a bit faded? First check your ink level if they are still ok. If they are then you can try cleaning it with a cotton swab with ethyl alcohol, make sure though that you let it dry before trying to print if the same problem persists then that means that the print head may already be scratched or damaged from wear and tear. That would mean that it needs changing although it can be quite expensive sometimes as much as the cost of a new printer. That being the case best step is a replacement.
    Master:
  • 382 Answers
Please Try to Replace the catridge hoping the fact that you mean the printing quality has deteriorated.. Thank you
Regards!!...
  • Natesan Sabesan
    Natesan Sabesan Aug 21, 2008
    Well then the most obvious reason could be print heads..The print heads get worn out after due usage of time..So Try to replace of then to get better results...Thank you...
I have a Canon I9950 printer it started playing up and despite head cleaning in warm water etc as recommended still did not print all the colours. I bought a new print head and new canon inks (always used...
I would check to make sure that the contacts on the cartridgew sensors are not fouled with dried ink. A q-tip with rubbing alcohol should help to remove the dried ink if that is in fact the problem.
Oct 19, 2013 | Office Equipment & Supplies
How to clean out the ink bin on canon i9950 please
follow my link below to another fixya solution that may resolve your problem also, as it lists waste ink reset instruction for many canon printers there.
waste ink reset instructions
Nov 18, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
I can't print with cannon i9950 in windows 7
Canon i9950 Printer -windows 7 Driver Problems
But the October 25, 2009 driver for 64-bit Windows 7 is at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=9870
Did you look for this at Canon?
Sep 30, 2010 | Canon i9950 InkJet Printer
Suddenly no ink coming from five wells (BK, R, G,
I have the same problem but it's only with the black ink, I removed the print head unit and run it under the hot tap till th ewater ran clear, then i soaked it in hot water and again run fresh water through it till it ran clear then left it in a bath of alcohol, i just used whiskey, but wouldn't recommend drinking it after, or before for that matter, I felt there was nothing to lose if it was a faulty print head as they are about £95 new. I had already run several deep cleaning programs and replaced the inks, but literally no black ink at all was printing. I havn'e tried it yet as it's still soaking, but I have also stripped the cover off the priinter and am trying to clean otu the waste ink tanks and absorbant pads, it's far to expensive a printer to just chuck out so here's hoping
Brian.
Jul 23, 2010 | Canon i9950 InkJet Printer
Black ink cartridge changed on my canon i9950 but it won't print
Your printer will need either a new printhead, or possibly a purge assembly that cleans the printhead. Best to have a shop check it out so
you don't buy a part you don't need. If it can't clean then even a new printhead won't help.
Jun 22, 2009 | Canon i9950 InkJet Printer
Error 5200
Sir,
Go through this link and check out
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950 colour deterioration
You can try changing cartridge but that would help little since the print head on canon printers are on the printer itself. Although you can give it a shot first since that would definitely be the cheaper option.
Aug 21, 2008 | Canon i9950 InkJet Printer
My Canon i455 will not print black ink
Hi , try to clean head until the black color will complete visible .clean also the ink retainer or tank replace with clean absorbent.
May 09, 2008 | Canon i455 InkJet Photo Printer
Will not print some colours
Rhis seems to be a printer Firmware problem, Nothing for it but to bin the printer and start again.
Nov 13, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
65 people viewed this question
old marine
old marine
