Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Power to T.V. went out
I was just watching T.V. and it completely went out, no sound and no picture. I replaced the two IC's about a month ago and everything was working fine until last night. Could you, please, tell me what I may need to replace now? Thank you very much for your time.
  • 4 more comments
  • Carissa1 Sep 04, 2008
    The Samsung HDTV 47" rear projection, model: HCP4752WX/XAA has been going in and out for a few weeks, it certainly was a tell tale that is was about to go out for good. Any help would be appreciated, thank you.
    I already tried unplugging it, it certainly works for about five seconds! That's not waht going out.
    Where is the power supply chip and what model # or part#?
    It's obviously a power supply issue ( I mean from my inexperiance :). Please, explain why it could be the two IC's again?
    I have checked my a/c wall power socket and this is not it, It surely is within the T.V. I can hear it trying to power up, it will even illuminate the red power light next to the power button on the front of T.V. (sometimes) but, nothing happens when the button is depressed. thank you.
    I would like to know more about this and if could be the switching IC or the MICIOM
    President:
  • 1,952 Answers
Check ur tv socket and problem of electricity
Posted on Sep 04, 2008
    Scholar:
  • 125 Answers
As per the manual, try unplugging the tv for 30 seconds then trying again. Press the SOURCE button, check that the antenna connections. Trying calling their tech support line at 1-800-SAMSUNG. You can trying looking through the manual at this link if you no longer have yours: http://www.fixya.com/support/p207848-samsung_hc_p4752w_47_in_rear_projection/manual-2020/page-66
  • Mighty B
    Mighty B Sep 04, 2008
    I also had a friend whom had this issue and she was told to replace the projector light and meter.
  • 2,322 Answers
If the convergence STK ICs failed again, that could also cause the no power on your TV.
Click here to find more info on how to diagnose the no power.
  • Jaime Hernandez Sep 04, 2008
    Depending on how they failed this time, they could have affected other circuits that are connected to the same voltage supplied to the ICs. You can still try the suggestions from the link to isolate the failure to the power supply.
    Have you done any hand soldering before replacing the STK ICs?
    Did you apply thermal compound to the back of the ICs before soldering?
    Genius:
  • 1,269 Answers
You need to replace the power supply chip. Check the fuse as well if it's burned. Another thing to check if there are any other burned components. If you found one, replace it as well.
  • Michael Galve
    Michael Galve Sep 04, 2008
    Trace the power cable going to the circuit board. The first chip that is in series with the power cable is the power supply, check the manual of your TV for the part #.
    How old is this set? If still under warranty then Samsung will cover it.
    If just out of warranty and you call Samsung sternly they may still cover
    you on it. If over 2 or 3 years of age you will have to repair it on
    your own ticket by locating some burned components other than power supply or STK ICs. If over 5 years of age you may want to think whether
    to repair or not.
  • Samsung Master
  • 19,396 Answers
Try first unplugging tv for one hour .
  • 3 more comments
  • Ginko
    Ginko Sep 04, 2008
    Try first unplugging tv for one hour, often if the safety switch starts and tv does not start.
    by draining power you reset the tv eeprom, and often you solve the problem.
    Test also on a different socket.
    If that does not work the TV must be tested starting from the power supply.
    If there is nbo power at all check the fuse on the power supply. check also if the power cable has shorted. If the power plug is fused (eg in UK) check the fuse in the plug.
    If you have the red led on the intenal boards must be tested.
    If you get an error code or a led blinking a number of times report the code here.
  • Ginko
    Ginko Sep 04, 2008
    If it is the power supply usually you have no power at all.
    Here you get all parts for your model.
    This should be the power supply: POWER SUPPLY
    call them at
    1-866-925-PART (7278)
    to ensure it is the right part and , after testing the power supply, buy it.
  • Ginko
    Ginko Sep 04, 2008
    If it try to power up, then switch itself off that is the safety switch , it means a fault had been detected.
    It can be bad voltage from power supply or a different internal fault, there are several thousends components inside the TV.
    If you want to do it yourself you need to get the service manual and follow the troubleshooting diagrams. Testing components and measuring voltage out.
    You start testing power supply.
    If you recently replaced STKs also test convergence board, test the pico fuses at the base of STKs for continuity, if the convergence ICs had blown again, then it is a powering problem on convergence board, in this case replace convergence module.
  • Ginko
    Ginko Sep 04, 2008
    The internal switch is not the problem, that is not the fault and you cannot bypass it , it is controlled by what is called the jungle chip, the TV main CPU that controls most important functions.
  • Ginko
    Ginko Sep 04, 2008
    If you decide to DIY test the most obvious first, test components on convergence board.
    If you do not find the fault contact the seller here: parts for your model,
    and order the service manual.
    Follow service manual to test the rest of the boards and buy parts.
    Unplug TV from power one hour before taking the unit apart.
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Sony KP-51WS500 wil not turn on
did you notice any color flashing at all during the poping? As that model is fairly famous for the green CRT shorting out or the flyback arcing. Does the power LED light up at all or possibly blink? Let me know about the LED and I will try to help you diagnose what the problem may actually be. respond to this same post, so I can keep this problem seperate as I have so many responses with different problems that its hard to keep them straight unless we keep using the origional request each time.
Posted on Jun 19, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
My tv is called a mirai or something. About an 1 hour ago tonight, i was watching britain's got talent while i was putting things away then when i turned my back to look at my tv all of a sudden my tv went...
If you have sound,than a bad ground may have occured on the horizontal transformer or the vertical IC. These will have to be resoldered. In the event the vertical IC is resoldered you should have the capacitors immediately near this IC checked and replaced as necessary! I would imagine you are speaking about the older picture tube type TV. This info is for most tube type TVs. Hope this will help! Thanks for asking!
May 30, 2010 | Samsung TXJ2554 TV
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
We had the convergence fixed about six months ago, now picture and sound are intermittent. We love the quality of the picture and really want to keep it. Any ideas what it could be would be helpful. ...
There is a kit that replaces heat sink on verticle ic . This heat sink has post on it that solder on the board . they complete a ground but the post where they mount to the heat sink does not make a good connection.
Nov 21, 2009 | Hitachi 53FDX01B 53" Rear Projection...
After 2years and 9 months the picture went black,
Most likely, capacitors in the power supply are bulged. It is not an expensive repair.
Jul 01, 2009 | Philips Televison & Video
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
NO PICTURE
sounds like the vertical output is causing the CRTs to shutdown for protection. Try resoldering the vertical output IC that will often correct the problem. If not the vertical output IC may be defective.
May 17, 2008 | Samsung HCN4226W 42" Rear Projection...
No picture, but power light and sound OK
The problem you have there was a loss of vertical deflection followed by a complete failure of Q301, the vertical Ic LA7833S.
It may have been in part due to the feed caps located in that circuit and there will likely be NO outward signs of the failure.
The Ic needs to be replaced and the electrolytics in that circuit need to be measured with and ESR meter and replaced if bad.
If it's starting to sound a bit beyond your ability I strongly suggest having a qualified shop do this because you can overheat the vert Ic easily just soldering it in...
If you have a shop do it you might ask what they charge to replace the vertical Ic and ESR the caps in that circuit. Explain to them what you have here with regards to how it went out, dropping to a horizontal line before going completely dead... The more detail you can give the easier it will be for the tech to troubleshoot the problem.
Good Luck!
Bill
Nov 24, 2007 | Toshiba 50H72 50" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Henry  Thomas
Henry Thomas
