What tire pressure are you inflating to? It should only be 22psi. Here's some advice from philandteds.com/support:
First, deflate all of the air from the wheel. Once the air is removed, reposition the tyre tread so that it is even all the way around the rim. Once in place, reinflate the innertube (while holding the tyre tread) and it should allow the tread to stay in the correct location to allow the stroller to roll smoothly. It may take a few tries, but this will almost always fix the issue.
There is an official Mount Buggy Spare Parts supplier and service agent based in Sydney, Australia called Karlisles. I'm not sure which country you are in.
In case it helps their details are:
www.karlisles.com.au 1300 308 435
Alternatively, a good bicycle shop in your local city can usually supply these parts and service jogging prams.
THe Mountain Buggy is very simple to fold. Level with the footrest, there is a black plastic button (either side), these simply push toward the back of the pram and hey presto! The pram will collapse. To make this as small as possible, keep the front two heels on swivel so that they tuck neatly underneath and the handle bar adjusted to the lowest position.
