Need to source powerboard for hitchi plasma tv 42" current board mada by RATA or WWRATA. boaRD ID IS MPF7415 PCPF 006646 ANY IDEAS PLEASE
  • EYEMAN1 Aug 21, 2008
    Dan
    Sorry forgot to add detail (grey moment)
    From the back of the set: Model PW2 42PD7200
    Big thanks for your efforts
  • Anonymous Sep 27, 2008
    the model # is MPF7415
  • 4,234 Answers
Could you post the model number please. There is no reference based upon the number you posted. It will be easier for me to cross reference based upon the model.
Thanks,
Dan
Posted on Aug 21, 2008
Where can I find a upper Y board for a Pioneer PDP-5050HD Plasma TV?
Easiest way is to get the ID number from board and put it in Google search, or ebay, surely you will find many, used and new, but you have to start with board ID for the make and model of TV is often using the same boards from many other brands.
May 03, 2014 | Dell W4200 42 in. HD-Ready Plasma...
I have a LG 42 inch plasma that turned off and doesnt want to turn back on. im thinking is the sensor is there anyone that can help out with this problem?
If you can turn it on with the button on the unit itself then it may be the IR sensor, but if you can't turn it on then it is very unlikely the sensor.
The power supply board of the 42PG20-UA is a known source of exactly this problem, although definitely not the only one that could possibly cause it.
Below is a link for a repair of the board, but the listing also contains a link to an article on how to test the power supply board alone, which is pretty useful before spending time and money sending it for repair. If anything you can rule one board out:
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
Nov 17, 2012 | LG 42PG20 42 in. Plasma HDTV
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
FUNAI TV
Since its plasma TV so very hard to find parts / boards.
Problem seems in digital video processing board and Part Store would be good source of boards for your TV but you need TV tech to examine and decide what board should be replaced.
Jan 29, 2009 | Funai F42PDME 42 in. Plasma Television
Plasma tv picture went black
I would say you dont need to repalce Servcie kit.kit is only for 42EP24S units.
examine your unit What is the problem?Is the blue indicator on?If indicator on you will have audio.
In this case I would check first Y-sus board or Z-sus board.
Good luck
Dals123
Sep 28, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Tv wont turn on
You can check the two board.
One is Power board another one is Y-main.
You can find right part with serial # & version #.
Jul 05, 2008 | Samsung HP-T5044 50 in. Plasma TV
No power
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Power board faulty deawoo 42 plasma DP42SP
this seems to be a common fault & very hard to find a replacement powerboard- & some places have refurbished powerboards & want extortionate money- for a tv this old its not really worth it-
Apr 20, 2008 | Daewoo Televison & Video
Dell 42" 1080i plasma issues after TV warms up
the power board needs to be inspected. you need a t20 torx bit, and phillips screwdriver. do not work on unit around carpet. stay away from carpet.you need a digital multimeter as well. remove back cover, and set meter to VDC. take black probe, and stick in one of the upper holes. look at the top right of the panel for a white sticker. this gives the proper voltage readings. on the power board, located middle top (big bd) look for the vs, vset, va, vsc settings on pow bd with red probe, test each one for proper voltage if 2 or more mismatches, the power bd needs replaced. do a ebay search for bd id number located on bd or simply type dell 4201 power bd.
Jan 23, 2008 | Dell W4201C 42 in. Plasma HDTV
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
