Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore side by side by side model #40654582400
When I open both doors the middle piece that seperates the freezer from the freig is very hot it could burn your hands off.
Please let me know what you think it could be?
Thank you,
Kim Erickson
I have the exact same problem. open up the bottom and clean the coils underneath - probably loaded with dirt and lint. it seems to have helped for now although i'm not sure it is a permanent fix
Posted on Sep 06, 2008
SOURCE:
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
The seperator between my Hot Point side-by-side, the piece of metal that is inside the refrigerator that seperates the fridg. and freezer is very hot, where the doors close on...why???
this is usually an indication that the condensor an has stopped working and is unable to cool the condensor lines and this heat is being transfered to the rest of the fridge .
Feb 02, 2010 | Refrigerators
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The outside middle front & left hand side of the fridge were hot
The reason you feel heat by the middle of the door is because of the "mullion heater' or anti-sweat.
Check the temperature of the freezer, must be below 12*F for the ice maker to work.
Apr 23, 2009 | Kenmore Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
