Question about Canon Speedlite 430EX TTL Flash
Batteries leaking Hi I bought the best batteries duracell from Costco and could not figure out why the batteries leaked in my light???is it the batteries or the Flash??
Should be the batteries. I only use rechargeables. Never had a problem.
Posted on Nov 23, 2008
SOURCE:
Hamilton beach Bottom loaded hot/cold drinking water dispenor leaking, bought from costco
nothing we know of will fix it tell costco about your problem
Oct 15, 2018 | Cars & Trucks
How do i open the flash light to change the batteries in a duracell 500
This query is not really relevant to Cameras, now is it, dear ? Have you looked in the manual ?
Oct 01, 2017 | Duracell Cameras
My mini 8 has all lights flashing. Put in the right batteries but the flights are still on and the flim keeps spitting out....
Hi! Please try this out:
1. Leave the mini 8's lens open.
2. Then try to put on the batteries again. (with the lens open.)
3. If it doesn't work, then try it again.
*It's important to see first if your battery is not defective or it is not leaking, and it is recommended to use high-quality batteries like Duracell.
(Reference:Youtube)
Hope this will help. :)
Aug 17, 2017 | Mini Cars & Trucks
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
Grundig Sattelit 800 radio-batt blinks w/new Duracell Alkakines from Costco(so they are fresh; good till 2024)
I have talked to the gentleman who designed this radio and he said that in order to correct this problem two pins on the inside of the front panel must be shorted while 6.2 volts dc is fed to the battery terminals. The whole radio must be disassembled to reach these pins, I have not been able to find a service manual to help me locate said pins. If anyone out there can find out where to get a service manual please contact [email protected]
Oct 20, 2014 | Grundig Satellit 800 AM/FM/SW Radio
Battery usage?
Duracell are the equivalent of several cheapo batteries and
they dont leak! Cheapo batteries if they leak can damage your
camera really badly..dont ever leave them in the camera.
has the camera got a socket for an AC adaptor
May 31, 2014 | Nikon L28 CoolPix 20.1 MegaPixel Digital...
Do watch batteries leak?
And destroy the watch? Yes, but not as much as regular batteries do. The old alkaline batteries in flashlights are notorious for leaking, I have seen a couple times when the little batteries leak, One of my calculators leaked, but I caught it just in time. Cleaned up the contacts, and it works fine. If the battery did leak, send the whole watch and battery back to the manufacturer, they should replace it. Duracell has sent me a dozen flashlights and numerous battery coupons for leaking batteries. Hope this helps.
Feb 26, 2011 | Panasonic CR2016 Lithium Coin Battery
RCA wireless headphones WPH141 Batteries leaking
Good Quality new batteries will not leak.
Excessive heat might cause a battery to leak.
Batteries should not be stored in a place that will expose them to high temperatures. The same would be true for wireless headphones with batteries in them. The dashboard of a car would be a very bad place. Shelf life of batteries is limited. New batteries and low temperatures should help.
Oct 05, 2017 | Sennheiser MX 500 Headphones
Canon Speedlite 430EX TTL Flash Logo
198 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
