Question about Konica Minolta magicolor 5430 DL Laser Printer
Keep getting black marks on printed documents.
You have unused toner in the media path. run a blank print job through 2-3 times and it will clean the path
Posted on Oct 18, 2008
1 copy to front and back from computer
umm if I understand correctly you want one document printed same document on both sides select double side printing the where it ask for how many copies you want send to or how many of the documents you want in increments of two ex. 2=1 double side copy,4=2 double sided ,6=3double sided
May 21, 2014 | Kyocera CS-2550 Black and White Copier
Black smudges & missing lines
replace the black image unit and the fuser
Apr 07, 2014 | Konica Minolta - Magicolor 1600 1600w...
I don't know how to disable "keep printed documents". I have an Artisan 800 series printer.
Hi Michelle,
Follow the steps below and you will be able to fix the issue.
Click on START button
Click on Control Panel ( or Settings for windows XP )
Click and open Printers and Faxes ( or Printer folder icon )
Highlight the Printer icon and Right click on it
Left Click on Printer properties
Click on Advanced TAB on top and look for "Keep Printed Documents"
If there is a Check mark, you can Uncheck it.
If there is no check mark on it, Check mark it.
Click Apply/OK and Close the window and try to print.
If this does not resolve the issue, Try the step below
1. Open Printers and Faxes.
2. Right mouse click on the Epson printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Regards,
Sean
Sep 14, 2012 | Epson Artisan 800 Series
I am getting a thick black line in the middle of my printed document when I use my mfc 8220
I am going on the presumption that you are getting this thick black line when printing from your computer. It can be a couple of things but firstly remove the toner/drum unit from the printer.
Check that the blue tag at the end of the top end of the drum unit ( used for cleaning the corona wire or drum unit & slides from 1 side to the other. ), is in the correct left correct position. If it is in the middle then that is what is causing this mark. It should be on the side of the drum unit where the arrows match.
If the blue slider is not in the middle then have a look at the drum & see if there is a black mark around it. If there is then you will need to replace the drum unit.
If you are only getting this mark when photocopying or faxing then there is a mark on the small piece of glass at the left hand side under thye document feeder.
Jul 17, 2011 | Brother MFC-8220 Fax
Problems with greyscale printing as colour on the Canon CLC3220
From whatever software you are printing, you will need to select the properties or features. In Pagemaker, it was features, but most other programs I now see it under properties for the 3220 on the print screen. You will need to find where it gives you the options for color. They should be color, greyscale or black & white. The default is generally color. Generally the 3220 will know if it is not a color document and print the black and white as a greyscale, but sometimes you have to force it.
If you are printing crop marks and color bars, then your document is recognized as color even though it may not be.
Finally, some programs use a black that is actuall 100% of CMY & K. If you are using InDesign and select registration as your black, instead of the plain black, then you document is recognized as color.
The same holds true if you select a pantone grey which is created from several colors. So also make sure that your document is truly greyscale and or that you tell the copier to print in greyscale.
Jun 16, 2009 | Canon Office Equipment & Supplies
Smudging
please check the pc drum, if there is also a mark in same location, then you have to replace pc drum, if not, take a look at transfer belt, same options, if TBU is also clean, then see fusin unit rollers.
Oct 21, 2008 | Konica Minolta magicolor 2300DL Laser...
PAPER PRINTING OUT WITH BLACK LINES AND MARKS
When coping I have a black line down the left side of the page. This only happens when I'm copying NOT when I'm printing off a document from Word or the Internet on my computer. How can I get rid of this black line?
Aug 14, 2008 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Konica Minolta magicolor 5430 DL Laser Printer Logo
156 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
