Question about LG Dishwashers
Model LD 1403 W!- 6 months old. Commences cycle and then error message OE appears
  • 641 Answers
SOURCE: error
The ?OE? indicates drainage trouble. It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 16, 2007
SOURCE: "PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
I think you have the same problem as me. If you close the door HARD or give it a good bang - problem goes away? http://www.yellow-mini.co.za/dishwasherfromhell Cr@p board.
Posted on Sep 26, 2007
  • 1003 Answers
SOURCE: LD-14AW1 keeps coming up with OE error code
REPLACE PCB POWER CONTROL BOARD
Posted on Jan 18, 2008
  • 351 Answers
SOURCE: LG Dishwasher Model LD-14AW3
you have a blockage in the drain pump.they are difficult to get to.
Posted on Mar 28, 2008
  • 210 Answers
SOURCE: LG LD-A2T2 Dishwasher returns Error code E1
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
Posted on Jun 19, 2008
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
My husband has just installed a LG LD 14AW2 which was given to us
OE = Outlet Error It involves everything related to pumping the water out. Easiest is to start at the drain and work back. Check for a plugged drain. then a kink in the drain hose. A plugged hose?
If problem remains, remove lower rack and unscrew/remove the filter from the sump area, looking for debris. Rinse out any filter in the mesh filter. Look again for anything that is blocking the drain outlet. Reassemble and run a cycle.
If problems continue, the probable cause is a failing pump motor. Servce call time.
Good Luck!
Mar 30, 2009 | GE GSD5920 Dishwasher
Sgt 48
Jun 18, 2008 | LG Dishwashers
LG Dishwasher
ok. our machine has done this for 6 months or so, it was ok for the 1st 6 months. i have checked and cleaned and unblocked and gone bloody crazy. today i found the fault and fixed quickly.
the installer stuffed up. the waster water hose must head up and be fixed just under your bench top, then come down hill to your exit/spiggot/drain attachment.
ours was just lying more or less at floor level coming up to the spiggot. so whenever the waste water pump switched off, water would run back into the machine, hence the OE error, and also dirty water with food would then get chucked around it what should have been a clean rinse.
a diagram of the waste water house and how it should be done is in the manual.
i just about blew $1500 on a new machine !!
Jan 17, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Dishwashers Logo
51 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
