Question about Dell A940 All-In-One InkJet Printer
Hardware error code 0502
Encodeer strip has come off! How do I get it back on?
  • 4,041 Answers
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Receiving hardware error 0502 on my A940 printer
Please use this link to fix -
DELL fix for 0502 error code
as DELL have provided detailed instructions on how to fix this one.
Jan 27, 2011 | Dell A940 All-In-One InkJet Printer
Can you please tell me what hardware error code 0502 is?
Error 502 comes from the encoder strip. Try the instructions located in the second thread at...
Cleaning the encoder strip (Loud bang from printer carriage)
Rick
Jan 09, 2011 | Dell Office Equipment & Supplies
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
Showing Hardware Error 0502
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Feb 07, 2010 | Office Equipment & Supplies
MY Lexmark X5150 All-In-One InkJet Printer displays the message: HARDWARE ERROR 0502
Unfortunately this appears to be a hardware failure and the printer is out of warranty. It is likely that the parts, repair and replacement fees would be more expensive than the actual cost of a new printer at this point.
May 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error 0502 and error code 50c
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. Lexmark will replace the printer, only if it is under warranty.
Apr 26, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error 0502
The encoder strip may have gone out of range of the sensor, or it might be dirty.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  11. Try to print....
Good luck...
Dec 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
My lexmark x6150 says hardware error 0502
Cause
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
    2. Disconnect the power cable from the back of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones you need to clean. IMPORTANT: Use a dry tissue.
    11. Perform the hardware test, first without the cartridges and then with both cartridges. Click on the applicable article link below.
      How to Perform the Hardware Test on the Lexmark X5150
      How to Perform the Hardware Test on the Lexmark X6150/X6170
Thank you
Nov 26, 2008 | Lexmark X6150 All-In-One InkJet Printer
Cant receive a fax
HI try this its from the lexmark web site
Nov 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
