Bush television model number idlcd32tv05hd problem switching on though theres definately power getting to it and the power switsh is working screen not
  • Daniel Liddy Jan 15, 2009
    Less than 2 years old, and when switched on an egg timer revolves for a few seconds and then nothing, just a blank screen. It does not even give you the chance to try and return to factory settings because the menu disappears in a split second.
    Can anyone advise.
    Regards
    Dan
  • Anonymous Apr 07, 2009
    have same problem
  • 3 Answers
I have same problem, i had a faulty switch, changed that and now.....nothing :(
Posted on Oct 12, 2010
Midwall unit works /cools for a while and switch off by itself,and comes on when switched on again with a remote, what is the fault with it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 11, 2017 | Bush Televison & Video
I have a bush flat panel tv model number LT42M1CFA which wont turn on, the power indicator on front of tv doesn`t come on either.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 16, 2015 | Bush Televison & Video
Bush Tv has stopped working. There seems to be no power to the tv. I have tested the outlet and changed the fuse in the plug. Is there anything else I can do?
Check and replace damaged component/s at its main power regulator board, or replace the board as card basis. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Try it in Mosaic view.
Jan 01, 2014 | Bush Televison & Video
I HAVE BROKEN MY TV REMOTE FOR A BUSH HD READY DIGITAL PLASMA TELEVISION MODEL NUMBER PT42GY638EB
It will be very difficult to get a universal remote control for this set. You have to contact the authorized service center for Bush at your town, to buy a new original remote control.
Oct 16, 2012 | Westinghouse 32 Flat Screen 720p Hd Led...
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
IDLCD26TV07HD BUSH, i am getting picture freeze when i turn tv over to channell 5 ?
had the same problem with a tv i was given. i went to
1-menu
2-digital set
3-reset reciever, you will get asked for a pass word, i tried 12345 and it worked
4- carried out an automatic search
i tryed the tv but had same problems, i put the tv away for a couple of weeks, then i tried it again, i had one freeze at first, waited for the tv to switch itself off, switshed the tv on again and it worked for 5 hours so far and it is still working as i am writing at the moment.
was your tv subjected to some roughing up? mine spent a couple of days in the boot of a car with bad suspentions and hot weather also came from a different transmiting area.
touch wood!
good luck.
Ben
Apr 22, 2011 | Televison & Video
I have a bush idlcd32tv05hd tv and since the digital switch over ive lost all my channels ive tried constant times retuning but nothing is coming up at all,it used to come up with all the channels that it...
I did search for your problem and there is a website in Germany that appears to be what you need for help and support. It does list your problem but to get an answer you gotta become a member. So here is a link to where I was: http://www.euras.com/repair_tips_1/BUSH/IDLCD32TV05HD/IDLCD32TV05HD_BUSH.htm
Oct 09, 2009 | Televison & Video
WHEN TV ON STAND BY .GO TO OUT CHANNEL ON SWITSHES OFF
Either the power supply is shot or the set is in sleep mode. Can you press any other buttons beside channel. Or can you press numbers?
Aug 30, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Bush TV, model number RF6685VPL/A - Colours are wrong!
It seems that it is a degaussing problem. TV sets have a degaussing coil that when the TV is turned on , it automatically demagnetizes the screen. Never place any speakers or anything magnetic near or on top of your set. if you see swirls of color and like you say, wierd colors, it is that the screen is magnetized. Turn it on and off with the switch. Not the remote control. The degaussing coil only works by manually turn the switch on and off.
Nov 19, 2008 | Televison & Video
Televison & Video Logo
334 people viewed this question
Top Televison & Video Experts
Electro Med Services...
