Question about HP Officejet 5610 All-In-One InkJet Printer
Copying problem in HP 5610 officejet all in one.
All functions except copy function were working but with the continue warning blinking light. ( with the display Insert Cartridge on left). My printer, scanner and fax are working ok but when i press copy button display shows unable to copy. Please help if you can?.
  • 234 Answers
Take out both the ink cartridges from the All-In-One.
Unplug the power cable from the All-In-One when there is still power in the unit.
Also unplug the power cord from the wall outlet end.
Leave it unplugged for at least 1Mins time.
Clean the metal contacts in the ink cartridge as well as the the inside of the All-In-One with a lint free cloth a little water (It should only be moistened with water not soaked) and make sure you will not touch the metal contacts with your hands.
Insert the ink cartridges back to the printer make sure they are not wet.
And connect the power cord directly to wall outlet without the surg protector.
And before connecting it to the All-In-One press and hold the # and No 6 Button in the All-In-One and insert the power cord without releasing the keys untill it comes up with a message as semiful reset or if the screen goes blank then release the keys and turn the power on.
And if it prints a test page it is fine.
Now try and make a copy and check.
Good Luck
Posted on Sep 08, 2008
  • Chibuzo N. Ekpo
    Chibuzo N. Ekpo Jun 06, 2011
    After the power on the Align page came on, and printed the align page which I placed faced down on the glass and pressed OK. But the power light kept on blinking for over ten minutes without the scanner flashing even once or moving down the glass. No other error message was displayed.
    Let me know if you have any other ideas.
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Mar 28, 2014 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro 8600 vertical lines on all copies
I had the same problem; it happened with the first copy I tried to make directly from the printer's console - but only with the Black ink function - with the same original on the flatbed glass I then tried the Color function and it worked fine. But when I tried the Black copy function, the strong vertical lines appeared again - about 7, evenly spaced across the page and running the entire length of the page.
Nothing about cleaning any part made sense: the printer was brand new, out of the box, the color ink function worked fine to copy; so did making scan copies. It was only the black ink mode in the copy function with the original on the flatbed glass that produced the vertical lines.
What cleared it up was shutting it down, removing and re-inserting the power cord the other way, i.e., turning it around (which might have nothing to do with the outcome) and Voila! - no vertical lines with the black ink copy function - Go figure...
May 29, 2012 | HP OfficeJet Pro K8600 Printer
Message on HP officejet 5610 All in one Error 0xd05d010d and on button,copy,fax,scan and alert yellow light keeps blinking on and off "tried reset the power cord still givwing same problem.Please help
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
HP copy function 'device not responding or is disconnected'
Did it work at all once you reloaded the software? Is the computer recognizing it in devices and printers? If it is present, right click on the printer, go down to properties and troubleshoot.... Let me know
May 11, 2017 | HP Officejet 5610 All-In-One InkJet...
Scanner won't work
did you try the copier function?if you can copy documents then the scanner is good,well if it wont works you cant print neither..but as you said you get a print out.reinstall it carefully and slowly..the logic board has no problem,just focus on the driver..
Sep 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't Scan
In order to scan it must be connected to your computer with a scanning program running. You can still make copies with the copy function, but it won't scan unless the HP scan software is running.
Jul 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 5610xi Solution Center Download?
Please go to www.hp.com and put officejet 5600 in the search bar and you will find the software program for it. If you can't find it there contact me and I will get it for you. 713-204-9111 or 585@snet.net.
Please leave me good feedback if this helped you.
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
We have an HP OfficeJet 5610 All-In-One and several times a day we need to fax two copies of the same document to a business. Is there a way to do this without running two copies through the fax?
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab90
Jun 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
210 people viewed this question
Seeker5211
Seeker5211
