Question about Samsung SCH-u740 Cellular Phone
Turn it on, all it does is vcast flashes off and on
When we turn the pnone on, all it does is flashe vcast off and on. Cannot turn it off unless the battery is removed
  • 15 more comments
  • phatymaty0 Aug 25, 2008
    I happened to fall into a lake with my phone in my pocket, and I have the same problem, it just flashes as though it is about to start up normally, then it turns off, and repeats over and over...
  • tnabb Sep 02, 2008
    same thing happened to mine. i have no idea what the problem could be
  • akrew Dec 01, 2008
    i dropped my phone, but i have dropped it before and the phone just keeps restarting and wont turn off unless i remove the battery
  • willialm Dec 04, 2008
    Same thing here. Samsung has so far been useless. Any ideas?
  • Anonymous Dec 09, 2008
    Yep, Vcast keeps flashing. Need some help.
  • masterszy Dec 20, 2008
    Yeah i have droped it before and now it just stays at the vcast loading thingy
  • Anonymous Jan 08, 2009
    same just keeps flashing
    really no one knows how to fix this?
    if so email me at
    sendithere313@hotmail.com
    Thanks
  • seandkane Jan 13, 2009
    when i go and turn on the phone or plug in the charger, the screen just flashes. The odd thing is, I didn't do anything to the phone. I just turned it off at night and wouldn't turn on in the morning.
  • OpenAirwaves Feb 04, 2009
    Yeah. The small front screen flashes between the vCast screen and black, while the main screen flashes between black and white.
  • Anonymous Feb 14, 2009
    Mine is doing the same thing. I was at work using it as usual and then all the sudden it started flashing the vcast screen. What a shitty phone.
  • surfrnut Feb 22, 2009
    v cast just flashes on and off !!!!!!!
    does anyone know how to fix this problem same thing happened to my phone. i did not drop or even get the phone wet. battery is in correctly
    help what can i do
  • cyanide1205 Mar 13, 2009
    i have the same exact problem!! i just got my replacement phone yesterday (the one before got stolen) and this morning i was texting..and then my friend was playing with it and it started saying "intial programming needed" and i was like wtf..i already activated it..so then i opened my phone 10 minutes later and the screen was black and it said "downloading file" and "image cannot be seen" so i tried turning it off but it wouldn't turn off..so i took out the battery..and i tried turning it back on and now the v-cast thing comes up and then the screen turns black and it just blinks...i have to take the battery out so the screen will stop blinking..
    my friend said that it might be because i over charged the battery..cuz it said to charge for 12 hours..but i charged it for like 15 hours..and that shouldn't make a difference..but she said that her dad had a verizon phone and the same thing happened..and the lady at the verizon store said that he overcharged his phone..and she pushed some buttons and it started working..
  • Anonymous Mar 24, 2009
    My phone flashes vcast and one time locked on problem at usb bootblock message. I tried several things like removing battery, holding end botton, plugging in charger and and holding the lock botton. There has no water damage or major drops. The crazy thing is i was using 1 hour before the problem was noticed.
  • irishtaylor3 Mar 30, 2009
    mine flashes on and off like that too!! any ideas?
  • eswanaset Mar 31, 2009
    Just flashes and won't turn all the way on. Was dl ringtones and all of a sudden, froze and now won't even turn on, just flashes. did not drop or get wet....
  • dksam May 22, 2009
    Turn it on, all it does is vcast flashes off and on. When flipped open as a phone, just says 'VCast'. When flipped open for texting, says VCast Phone'.
Same thing here... got caught in the rain, and now it just goes on to the V-Cast screen and flashes.  Removing the battery does nothing.  Tried a blow dryer to the case (didnt disasemble) but this had no effect.  Any ideas? abkapner@yahoo.com
Posted on Sep 06, 2008
This happened to me when I put the battery in backwards. When I slipped it around so that the "samsung' is on the outside, it powered up just fine.
Posted on Feb 20, 2009
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Turn on, all lights flashing, can't turn off unless i unplug printer
It's highly likely that your printer has reached the "service required" point but I couldn't be 100% sure.
I'd recommend downloading the SSC utility from SSCLG, get that installed and then follow the instructions for configuring to your printer model and resetting the protection and overflow counters.
If that works you'll then want to be thinking about cleaning the waste ink pads or installing an external waste kit.
If it doesn't work you have bigger problems and need to describe the flashing patterns and any other symptoms in detail.
Hope that helps.
Martin
May 19, 2009 | Epson Stylus Color 860 InkJet Printer
My check engine light does not flash when i turn key before start
bulb is probably blown... you have to remove the instrument cluster to change the bulb
May 14, 2009 | 1996 Lincoln Town Car
How do you reset this phone (Samsung Glyde
i can't charge my phone the battery says non supported
Jan 25, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Get pictures and video off phone to the computer
Preparation ? if an external Micro SD external memory card is to be used as the desired music/video/picture repository on the W755, install the card in the W755 behind the battery. Then go to SETTINGS & TOOLS ? MEMORY ? CARD MEMORY ? FORMAT and format the new card. Caution: reformatting the card will wipe out all contents on the SD card. Download/install free Motorolla Handset USB Driver Installer onto the PC (execute ?.msi? file). Download/install free VCast/Rhapsody software (no need to actually sign in or use the proprietary Rhapsody service). Start the VCast/Rhapsody software. Turn on cell phone (works with W755 and may work with other Verizon ?music phones? such as LG Chocolate, but the latter was not tested). Connect phone to PC ? connect USB cable to PC?s USB port first, then connect USB cable to phone . Be patient, it may take a minute to fully ?connect? in the phone?s display. Go to ?Sources? section of VCast/Rhapsody GUI screen ? the phone will register as a directory title using a name roughly like ?VCast xxx.? Windows Explorer will also show a ?VCast? drive/directory device. Files can be selected and dragged to and from source and target directories. At this point various options exist regarding music, picture, video management: 1.) The VCast/Rhapody software can be used to manage music, picture, and videos between the PC and phone. Again, no need to use the VCast service, just the software offline. 2.) Alternatively, other music management software such as Media Monkey (a personal favorite) can be used to move music, create playlists, etc. ? NOTE: Leave VCast/Rhapsody software running in the background as a means to ?connect.? It is best to start VCast, then plug in phone, then start other media management software so that the media management software will benefit from the connection (usually with a directory name using some variation of ?VCast.? Then use the alternative media management software as usual. Please note, this is a generalization based on success using basic software like Media Monkey, for example.
Apr 26, 2008 | Motorola Cell Phones
My samsung sch740 cell phone
my phone wont let me hear anything when i call people or when people call me anyone else having this problem?
Mar 31, 2008 | Samsung SCH-u740 Cellular Phone
Music
Sounds like he has the older version of software for the 8300
go to settings and tools , phone info ,SW version and see if your sw version ends with vo2, vo3 or vo4 .vo4 cripples some functions , v03 is the best in my opinion and vo2 is limited version also . unless it is vo3 take it to your verizon service center and talk to someone real nice and get then to flash it back or up to v03 , will take them about an hour to finish it.
you can also
Try pressing
OK
then the service code
0000000
then scroll to music setting click ok and see if the option to turn on mp3 playback is listed.
Dec 26, 2007 | LG VX8300 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
468 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
