Lamp burned out on panasonic PT44LCX65 TV 42" how do i replace it?
  • 4,234 Answers
THe lamp part numberis TY-LA1000 and is available for $250 from tritronicsinc.com. Complete installation instructions come with the lamp, including pictures.
Dan
Posted on Aug 21, 2008
MY TV HAD GREEN SPOTS AND THEN WENT BLANK. I REPLACED THE LAMP AND NOW WHEN I TURN IT ON THE POWER BUTTON BLINKS GREEN 3 TIMES AND THEN YELLOW 2 TIMES. THE SCREEN STAYS BLANK
The lamp will not fix the green spots. That is due to bad polarizers in the optic block. The lamp is only a white light. http://service.us.panasonic.com/OPERMANPDF/PT44LCX65.PDF
According to the manual you are not getting enough airflow which would explain the optic block failure. Make sure the TV has lots of space for air around it and is not inside a cabinet that would overheat it.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
I have a DLP Panasonic tv. The lamp indicator is red.Does this mean the lamp will burn out soon. If so where can I BUT A NEW LAMP.
there could be a possible problem on the convergence module, this is very common problem on the projection tv, kindly check the resistor & capacitor on that area.
let me know,
micro
Jun 30, 2008 | Panasonic Televison & Video
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
The tv is only 4 years old and just stopped working while we were watching it. it is a "52 model number pt-52lcx65-ka.
If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it.
Did tv showed lamp replacement requires warning/ message on screen before going to shut down?
Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken.
Let me know if you have additional question.
Thanks.
Feb 27, 2011 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I recently replaced my the lamp in my pt50dl54j with a new tyla2004 lamp, but there still is a black screen and the words "replace lamp" still comes on, but the menu and channel search for my...
The tv projection lamp on,now tv have alots clicking noises too?The board call the Ballast is also dead,require replacing.This Ballast board job is to ignite the projection lamp.
Feb 25, 2011 | Panasonic PT-50DL54 50" Rear Projection...
How to reset lamp timer for panasonic 61 in tv pt61lcx35
go to http://service.us.panasonic.com/OPERMANPDF/PT44LCX65.PDFand download it it is in the owners manual
Good Luckor contact customer support at
1-888-VIEW PTV(843-9788) Good Luck
techman
May 07, 2010 | Panasonic Televison & Video
Tv will not click for pic to show, bulb good, just blicks green
This TV has a Service Bulletin on it that indicates you should install a Ballast Kit.
Also replace the Lamp with a Panasonic Lamp / No generic.If you just replace the Lamp only, it will burn out fast without the new Ballast Kit installed first. Call a good TV tech and have him check for this problem first.
Jul 31, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Sony KDF-42WE655 Replacement Lamp
First thing i would ask is where is the smell coming from?
Jan 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lamp
Are you buying the original lamp from Panasonic? If you are, replace the ballast circuit in the TV set. Good Luck
Sep 18, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
