Question about Canon BJC 6000 InkJet Printer
Canon bj 4000
Hi when switched on the printer makes 5 fast beeps and does nothing else nothing moves nothing works its not out of ink and all cables are connected,
please help
thank you
dave
info@davedeediscos.co.uk
  • 4,041 Answers
1: Unplug Power Cord
2: Hold POWER and FF and Print Mode buttons
3: Plug in Power Cord
4: Release after the beeps
Posted on Feb 13, 2010
I250canon printer ink levewls How do i check inklevels
Try this steps, 1. Click "Start."From the start menu choose programs. 2. Click"Programs." Then choose "BJ Printer," then "BJ PrinterMonitor." The Canon BJ Printer Monitor window will appear. 3. Click on the Canonicon. This will take you to the printer info menu. 4. Click "Start StatusMonitor" from the Printer Info Menu. The Canon Start Status window willappear. 5. Click the "InkInformation" Tab to view the levels of ink in each tank in the printer.
Nov 20, 2010 | Canon Office Equipment & Supplies
How do I check the ink levels on a Canon MP460?
Look at the bottom right side of your computer screen and find the printer ICON. Right click on it with your mouse and open the option to check ink levels.
Sep 27, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My Canon s4500 not working, with 6 beeps error
    This is because the BJ Cartridge is not installed. Please refer to your manual page 214.
    Two beeps: Out of paper, or paper feed error
    Three beeps: Paper jam
    Four beeps: BJ Cartridge out of ink
    Five beeps: Cartridge not installed correctly
    Six beeps: BJ Cartridge not installed
    Seven beeps: BJ Cartridge defective
    Eight beeps: Waste ink tank almost full
    Nine beeps: Automatic print head alignment failed
    The POWER lamp flashes orange and green alternately with beeps: Service error
    YBC (/\)
    Oct 08, 2009 | Canon Office Equipment & Supplies
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Shows black ink empty after new cartridge inserted
    Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
    Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
    1. Make sure the MultiPASS is plugged in.
    2. Open the document tray.
    3. Lift the document guides to open the ADF (Automatic Document Feeder).
    If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
    Or slide the Document Feed Lever to either the automatic or manual setting.
    4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
    Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
    The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
    Press thingtopress.gifto move the cartridge holder.
    5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
    Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
    container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
    Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
    7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
    lockinpos.gif 8. Press thingtopress.gif.
    The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
    9. Close the ADF (Automatic Document Feeder).
    10. Close the document tray.
    Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
    Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
    Ink is fading fast while using brand new ink cartridges
    Have you replaced the Drum or is it a BJ-Ink printer?
    Nov 11, 2008 | Office Equipment & Supplies
    Canon bjc 4000
    Hello there try
    Aug 21, 2008 | Canon BJC 6000 InkJet Printer
    ERROR MESSAGE FOR CANON BJ-W9000
    Hi Caroline here is the problem defonition
    E7260
    : Nozzle check sensor unit error
    E7270 to E727b/W7280/E7281/E7290/ E7291
    :Nozzle check error
    <Cause>
    The position of the nozzle check sensor unit was faulty.
    An abnormal condition occurred in the nozzle check sequence.
    An abnormal vibration in the printer, the BJ print head is abnormal or no ink was
    delivered to the BJ print head.
    <Probable faulty component>
    BJ print head, nozzle check sensor ***'y, linear scale, encoder sensor unit, carriage
    controller, head controller, system controller.
    <Action>
    1. Check the ink filling status:
    Execute "Fill Ink" from the Service Mode when there is no ink in the ink tube of
    the carriage caterpillar component. Execute cleaning when the carriage air buffer
    is filled but the ink tube of the BJ print head locking lever is empty.
    2. BJ print head:
    Replace the BJ print head if the above procedure does not solve the problem.
    3. Nozzle check sensor check:
    Re-install the nozzle check sensor holder unit if the installation condition is
    incorrect.
    If the installation condition is correct, select "Nozzle Check Position" from the
    Service Mode, turn the power off and on, and obtain the updated and appropriate
    nozzle check position.
    4. Replace the nozzle check sensor ***'y.
    5. Check the linear scale:
    Visually check the linear scale for abnormal conditions, such as stains or damage.
    6. Replace the carriage controller.
    7. Replace the head controller.
    8. Replace the system controller.
    9. Replace the carriage unit.
    I hope this helps
    If not please get back to me
    Thank You
    Jun 13, 2008 | Canon BJ-W9000 Copier
    I have tried to print using my black ink cartridge and it will only print what is my email address.
    Issue: Tinted printing / Colors are not exact
    Solution: Resolving ink tank and cartridge issues BJC-6000
    Printer attempts to print but no ink is on the paper Printer attempts to print but no ink is on the paper If the print quality is poor or no ink is appearing on the page, it may be because of the following problems:
    • The ink in the BJ tanks has run out.
    • The print head nozzles may be clogged
    • The protective cap or tape may have been reattached to the BJ cartridge
    • The BJ cartridge may need to be replaced
    • You may be using the wrong side of the media.
    To check the level of ink in the BJ tanks
    Open the printer's front cover and visually check the level of the ink in all the BJ tanks. If a BJ tank is low or has run out of ink, replace it. Failure to do so may shorten the life of your BJ Cartridge
    To check the status of the print head by printing a Nozzle Check Pattern
    1. The Nozzle Check Pattern confirms whether the inks are being correctly ejected from the print head nozzles and whether the print head is correctly aligned.
    2. On your printer, press and hold the Resume button until you hear 2 beeps.
    3. When you release the button, the Nozzle Check Pattern will be printed. You can also print the Nozzle Check Pattern by clicking on the Test Print button in the Maintenance tab of the printer properties dialog box.
    4. After the Nozzle Check Pattern is printed, check the results. Look at the Nozzle Check Pattern for each BJ Ink tank. If any colors are missing or if any horizontal lines are broken or missing, perform the print head cleaning procedure.
    To perform the print head cleaning procedure
    1. On your printer, press and hold the Resume button until you hear 1 beep.
    2. When you release the button, all print heads for all colors will be cleaned.
    3. You can also clean the print heads by clicking the left Print Head Cleaning button in the Maintenance tab of the printer properties dialog box.
    4. When the print head cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.
    5. Perform the Nozzle Check Pattern test again.
    6. If the results are satisfactory, resume normal printing. If the results are not satisfactory, you may need to execute a print head deep cleaning.
    To execute a print head deep cleaning
    1. Make sure paper is loaded in the sheet feeder and the printer is turned on.
    2. Display the printer properties dialog box and click the Maintenance tab.
    3. Click the right print head Cleaning button.
    4. When the print head cleaning begins, the POWER light starts flashing. Wait for the light to stop flashing before you resume normal operation.
    6. If the Nozzle Check Pattern is still unsatisfactory, you may need to execute a print head alignment.
    To execute a print head alignment
    In Windows, display the Maintenance tab of the printer properties dialog box.
    1. Click the right Test Print button.
    2. Follow the instructions on the screens to perform an automatic print head alignment.
    3. A confirmation screen will ask you if you want to perform automatic print head alignment. Read the screen and click OK. Another screen warns you not to start any other operation until the alignment is complete. Again, click OK.
    4. The BJ Printer Status Monitor displays the Printer Status. The driver will align the print heads then will print an alignment pattern.
    6. If the Nozzle Check Pattern is still unsatisfactory, you may need to replace the BJ cartridge.
    To replace a BJ Tank in a BJ Cartridge
    Leave the BJ cartridge in the printer when replacing a BJ tank. Make sure the printer's power is on. Make sure you insert the BJ tank in the correct slot.
    1. Open the front cover.
    2. The power light blinks while the cartridge holder is positioned to the center of the printer.
    3. Remove the empty BJ tank by pressing in on the release tab and then lifting the BJ tank up and out of its slot.
    4. Dispose of the tank properly, taking care to avoid spilling ink on your hands, floor, furniture, or clothing.
    5. Remove the new BJ tank from its package and pull the orange tape up and against the perforations to open the package film. Be careful not to remove the label from the tank. You will need it to match the tank to the correct slot in the BJ cartridge.
    6. Twist the orange protective cap to remove it. Do not attempt to reattach the protective cap; instead, discard it along with the protective tape.
    7. Insert the BJ tank by holding it at a slight angle, aligning it with the correct slot. Press down gently on the top of the tank until it locks into place.
    8. Lock the ink tank in place by pressing down on the circle mark on the top of the tank.
      Close the printer cover.
    9. The printer will automatically start cleaning the print heads. When the print heads are clean, the POWER light will stay on, indicating that the printer is ready for operation.
    10. Perform another test print to make sure the new ink tanks are performing correctly.
    To remove the protective cap and tape from the BJ cartridge
    1. Open the printer's front cover.
    2. Unlock the BJ cartridge by raising the cartridge lock lever. Make sure you raise it all the way up.
    3. Remove the BJ cartridge by holding it by the circles on the left and right sides.
    4. Make sure that the orange protective cap has been removed.
    5. Make sure that the protective tape has also been removed.
    6. Replace the BJ cartridge and move the blue cartridge lock lever until it locks in place.
    To check the media
    Make sure that you are printing to the correct side of the media that you are using, and that the Media Type setting in the printer driver properties correctly reflects the type of paper you are using.
    Be sure to read any instructions that come with your Canon specialty paper. These instructions provide important information regarding how to achieve the highest print quality with these papers.
    May 30, 2008 | Canon BJC 6000 InkJet Printer
    Canon BJC 6000 InkJet Printer Logo
    47 people viewed this question
    old marine
    old marine
