SOURCE: Vivitar Vivicam 4100
I had the same problem and I think I may have just figured it out. Plug in your camera as you normally would. Then right click on My Computer and then click Properties. Click on Device Manager and locate the Vivicam 4100 USB Device in the Drives section. Right click it and Uninstall. When it is off the list, unplug the camera from the computer. With the camera still turned on, plug it back into the computer. There should be a little icon in the system tray that it is locating the drivers. It will take a long time so be patient. After a few minutes, a window should appear asking what you want to do with the new device. If you open the folder to view files, you'll want to make sure to copy the drive letter to make a shortcut to the desktop as the drive won't always or immediately show up in My Computer. Also make sure to Safely Remove Hardware from the system tray. I hope that helps. It was a pain in the you-know-what.
SOURCE: device driver for vivitar vivicam 3740
Vivitar Vivicam 3740 drivers
Manufacturer: Vivitar
Device family: Photography Digital Cameras
Operating system: Vista, XP
Some Vivicam 3740 drivers may be zipped. To install them, you will need the archivers WinZip or WinRar to unpack them prior to setup. If your Internet connection is unstable, use the download manager ReGet to simplify the downloading process.Before you install Vivicam 3740 software downloaded from our site, please make sure that the program really suites you. To download the necessary Vivitar driver for your device, click on the link below.
Go to this web page and save the manual as a PDF on your hard drive:http://www.vivitar-experience-image-manager.com/manuals/en_US/ViviCam_8018_Camera_Manual.pdf
SOURCE: Camera lens stuck!
Hello Friend,
First i would let you know that the Brand Vivitar is one of low quality cameras, it's sad but it's true.
Now regarding the issue that you have with the lens, you probably drop it because this the only way to have the lens stuck. but anyway, to repair it it will cost you more than a new one. and again i suggest to buy a branded camera like Canon,Sony,Nikon,Panasonic ... these are top quality cameras and you will not have any problem for life except if you drop it ;)
Best Regards,
