Question about Panasonic (ET-LAD35) Projector Lamp for PT-D3500E
PT-D3500E Projector projector failing to come on and showing the static green power light with the red light flashing aswell in the same power button. new lamp in it. and no other lights showing a fault.
No havent fixed this problem but also unwilling to pay for advice.
this is something that should have supplied by the contractors who installed and fitted
the said products. many thanks for getting back to me but i will now take this up with the project manager.
Posted on Aug 22, 2008
When I set my PT-D5500UL contrast mode to HIGH the picture have less light than when contrast mode set to NORMAL, is this okay or....because there should be more light when is set to HIGH?
I have a PT-D3500E and it does exactly the same as your projector. When setting contrast mode to high, the picture gets darker. I think this is o.k.
Oct 18, 2012 | Panasonic PT-D5500U Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes orange...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    What is wrong with my Panasonic PT-L711XU projector?
    try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
    jahting
    Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
    Problem with Power up on PTD3500
    Position reference device has probably fallen off the filter wheel, replace the filter wheel.
    Sep 20, 2007 | Panasonic PT-D3500U Multimedia Projector
    Panasonic (ET-LAD35) Projector Lamp for PT-D3500E Logo
    217 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
