Linksys (WRT54GC) Router Logo
Posted on Aug 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Internet Light Stays Red on WAG54GS Wireless Router
The internet light on the router suddenly changed from green (connected) to red (not connected) while surfing. We use Tesco Broadband and the green light stays green all the time as it is always connected. Tried re-booting the router - nothing, rebooting PC - no change. Thought it might have been Tesco.net server issue, but have been on it this morning at work with no problems. Can you help?
  • DougieBev Aug 22, 2008
    Sorted, we changed the password on tesco, and not the router. Accessed the router changed the settings for the Gateway. Re-booted and working perfectly
  • digshaz Feb 28, 2009
    Cannot get wireless on my laptop
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Aug 21, 2008
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
21584
Points
145
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
2answers
What does a red internet light mean and how do I fix it? I recently moved and when I plugged in my router the dsl light is green and the internet light is red. When I look at my laptop it says I am...
You'll need to contact your ISP and have the DSL service moved to the new line. The laptop sees the mdem or router and thinks it's connected, but the red internet light tells you the connection is not complete to the phone company.
3helpful
3answers
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
1helpful
No internet
If the power light is red this is a system error.
Try to reset the router by holding and pressing the reset button for 10 seconds. Then power cycle the router.
If the power light is still red. It is possible that the router is already defective.
1helpful
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
3answers
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
2WIRE Red internet Light
the poblem with the router settings, the router is not able to get internet address form the modem
log in to ur router and run the setup wizard, and then u will be able to go online
2answers
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
