Related Tags:
This problem should be removed because:
Problem with Maytag MSD2756G Side by Side Refrigerator
light on water and ice dispenser stays on all the time
Solutions (1)
Best Solution
Hello, aigarhart
I
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized
Trouble Shooter.
I have found out that it appears that lots of
customers appreciate my efforts and help. So, I thought I would take
some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Suggested Solution (3)
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
Source: ice and water dispenser not working but light on constantly
I had the same problem - I got it out of it by pressing a specific sequence of buttons - maybe holding one or more down when pressing another - Dummy me I didn't write it down. I am having the same problem now. I called Maytag - the local guy said he'd call back. I 'll keep watching here
Source: water/ice dispenser doesn't work
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Ice dispenser comes on by itself.
I opened the door to the freezer and when I closed it the ice dispenser began operating. Becasue the actuator was not pressed the ice began...
Ice and Water not dispensing. Light button not...
Fridge is a GE GSS25WG side by side black. Ice and Water is not dispensing from outside. Also, light button is no longer working. All other...
Stuck Water/Ice Dispenser LG LRSC26920TT
We are having a problem with the water/ice dispenser sticking on our LG Refrigerator. It has happened a few times in the past when I would...
I copied this from a
I copied this from a previous FixYa request. It exactly matches my GE PSH23PGRB-BB. I changed main board - it behaves the same! Interface...
Add Your Solution
Maytag msd2756g change filter light wont go off
Change filter but light wont go off
is a "hard start relay" ( brand name...
a hard start start relay was installen on my refrigerator, it was a electrical 115volts, the relay that was installed...
rsw22eodae not getting cold enough to make ice
Could this mean that the timer is bad. I replaced the Heater element and the Defrost thermostat about 1 1/2 yrs ago.
Fix-O-Meter
37
37 people viewed this problem
- 1 person found this problem to be helpful.
- 1 person is following this problem
Top Maytag Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
