Question about Graco Baby Gear
Pucture repair I have had a puncture on one of the back tyres unfortunately i do not have the manual and i do not know how to get the wheel off could you help me
Thank u for question but,would u please tell me back tyre of wat got punchured .thankk u .
Posted on Aug 21, 2008
Where can I find the full service manual for Bmw x1 2011? Brake pad, disc replacement, suspension, steering system alignment and balancing etc... Also how to repair the punctured run flat tyre on Bmw x1???
Take the flat tyre to a tyre shop and have it repaired there as believe or not , puncture repair requires the correct tools and procedure for safety. As for the rest a good workshop manual should have that information or get a service hand book from the dealer service centre.
May 23, 2014 | Cars & Trucks
Removal of rear wheel on a benelli tnt 1130
Hi Leslie, I am sorry you can't find the first and best tool you ever bought for your Benelli but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Delboy Garage Emergency Puncture Repair Motorcycle Tyre
How To Guide fix flat motorcycle tire
Benelli service manuals page 4
Benelli Manuals
https://dl.dropboxusercontent.com/u/35177464/Benelli/Katalog-d%C3%ADl%C5%AF-TNT-1130-Cafe-Racer-MY06-07.pdf
Aug 19, 2012 | 2011 Benelli TNT 1130 Cafe Racer
Change wheels on my Capo or more resilient tyres, to reduce punctures.
I thing you shud keep the tyres and avoid pit falls
Apr 22, 2012 | Cannondale Capo
Yamaha xc125e vity how to repair punture rear wheel
Hi, Steve for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
125cc Scooter back tyre puncture repair
How to change your own Yamaha Cygnus Scooter Tyre
Yamaha XC125 Service Manual
OEM parts for Yamaha
YAMAHA VITY XC125E Owner Manual
Nov 14, 2011 | 2009 Yamaha Vity
I have a bebecar ip op and i want to know how to detach the rear wheel as it has a puncture?
The rear wheel is held in place by a locking clip which is controlled by a lever. To remove the wheel, simply press the lever rearwards, and pull the wheel away from the housing. Remove the tyre carefully, using appropriate tyre levers, in order to repair the puncture in the inner-tube, or to replace it.
Mar 27, 2011 | Bebecar M City Stroller
Can i change my pulsar 150 2003 to alloy wheels with tubles tyre and what is the advantage after changing this
That sounds like a lot of work and expense, if alloy wheels are available. Unless you have some alloy wheels of another bike and the axles, sprocket and brakes are compatible.
There is no real advantage, apart from tubless tyres can sometimes have punctures repaired without removing the tyres from the rims.
If punctures are a worry, then fit heavy duty inner tubes, which will last for years
Feb 25, 2011 | Bajaj Pulsar 150 Motorcycles
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
BMW i system
this needs to be reset with a scan tool capable of doing european cars, call around and see if some one has this tool, get back to me if you need more help.pleaserate my fix as i strive to be te best Thanks Ray
May 12, 2009 | BMW 525 Cars & Trucks
Flat Tyre
take the wheel to a pram shop or a bike shop thay should be able repair it
Jan 08, 2008 | Hauck Infinity Standard Stroller
Baby Gear Logo
174 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
