Question about Tally Office Equipment & Supplies
TALLY 2030g matrix printer - paper loading problem
Our printer has been working fine for a long time but we have just changed the paper and are now received a message that says "load paper from single". The printer has stopped printing now and we have no idea how to solve this problem.
please help!
  • 48 Answers
Ok...well..is the new paper the same as old? sometimes, when a printer handles a certain type of paper, for a long time, it becomes accustomed to that type, and will resist a new type of paper(kind of like us, eh)?
at any rate, that might be the issue here
Also, more printer resources are here
Posted on Aug 21, 2008
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
Telegenicom 6312 printer has a paper out problem
there is a sensor that check the paper its mey be broken or jamed
Nov 10, 2011 | Tally 6312 Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
I have a Tally T2245 with load error. ASF-R
Sounds like the paper path has been changed I guess you are using the front Tractor (tractor 1) to load continuose paper.
You need to go into the menu and change the paper path back to Tractor 1.
Disconnect the pritner from the computer system, and power the printer off and back on again to clear the buffer.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • This should change the paper way back to Tractor 1
    Jun 23, 2009 | Tally T2245 Matrix Printer
    TALLY 6218
    Hopefully, you have paper in there!! LOL! Some times if the paper is not inserted correctly, the printer won't reqcognise that there is paper there, just pull it out and reinsert it, sometimes you have to do it maore than once.
    Jan 05, 2009 | Tally T6218 Matrix Printer
    Paper width error on tally genicom 2280+ printer
    Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
    ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
    Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
    Tally T2250 Matrix Printer does not pull up paper to be printed
    I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
    I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
    To do this;
    • Stop any prin jobs gong to the pritner
    • If the printer has data in its buffer, power the printer off and back on again to clear this data
    • Ensure the printer is OFFLINE
    • Press the SETUP button
    • Press the button under ADJUST
    • Press the button under PAPER WAY
    • Use button 2 or 3 to change this to TRACTOR 1
    • Press SET
    • Place the pritner ONLINE
    You should be back in action, if not post the message you see on the printers LCD display.
    Dec 18, 2007 | Tally T2250 Matrix Printer
    Tally printer form feeding continually on its own
    When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
    May 01, 2007 | Tally T6215 Matrix Printer
    252 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Tony
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
