Question about Avaya 4602SW IP Phone
My Avaya 4602sw having registering problem
When I tried to configure a new Avaya 4602sw phone, i configued all the values like call server gateway etc. after that it will ask extension and password, after giving extesion and password showing registering it will take hours but it dot not registering
can you help me to recover from this problem ?
Tenne
    Problem Solver:
  • 10 Answers
Ensure the follwoing things:-
1. If there's a firewall in between.... ports 1719 and 1720 must at least be open.
2. The extension number and password used have already been configured in the system
Posted on Apr 02, 2009
Has this been fixed yet?
Posted on Nov 19, 2008
SOURCE:
How do I cahnge the ip address on the linksys spa941 when it failed to registered: it is not picking up ip address from the switch.it was working before change the switch
Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys IP PhoneThis document explains how to use Brekeke SIP Server with the Linksys IP Phone SPA hard phone .
The Standard features include two active line appearances, call forwarding, redialing, speed dialing, transferring calls, conference calling and accessing voice mail. For more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and subnet mask (e.g. 255.255.255.0).
Once the IP address is configured you can access phone webpage by its IP from web browser (e.g. http://192.168.0.15). Network SetupClick on "Admin Login", then select “System" tab. Sign Static IP, Gateway and NetMask.
Use the following data as an example
  • Static IP: Linksys phone IP (e.g. 192.168.0.17)
  • Netmask: 255.255.255.0
  • Gateway: not needed if SIP Server is in the same LAN as Linksys phone
  • Click on [Submit all changes] button now to reboot you phone,
    or after whole setup is finished
Phone ConfigurationSelect tab Ext1 or Ext2 and enter SIP server information and sign extension number
Use the following as an example to complete the phone configuration.
  • Proxy and Registration:
    • Proxy: Brekeke SIP Server’s IP address (e.g. 192.168.0.69)
    • Register: Yes
  • Subscriber Information:
    • Display Name: extension number or Name (e.g. 400 or Alice)
    • User ID: extension number (e.g. 400)
    • If user authentication is set on at Brekeke SIP Server,
      type in the same information at Auth ID and Password as what you set at SIP Server side
      and Use Auth ID: Yes
  • click [Submit All Changes] button to restart the phone
phoneconfig.gif Brekeke SIP Server’s Registration PageClick the [Registered Clients] tab at Brekeke SIP Server admintool.
The Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
Jun 09, 2010 | Linksys SPA941 IP Phone
How to remove a avaya phone from the intra-switch
What do you mean? Remove from user profile? What system is this phone on?
Jan 08, 2010 | Avaya 4602SW IP Phone
Is it possible to get the missed call information from avaya 4602 sw ip phone model..
No. BUT, you could use phone manager linked with that phone. Phone manager Pro would get you that.
Nov 04, 2009 | Avaya 4602SW IP Phone
The Avaya 4610sw phone will not find the main phone system an Avaya G350 it has been unplugged from the system and when it was plugged back in it would not find the router or system
It's probably a problem with your DHCP settings, if you try manually setting the IP configuration on the phone it should find the server/control unit, haven't used 46x series myself, but if you reboot the phone at some point it should give an option to configure manually, if you have another working phone you could get the IP configuration off that one, think you can find them somewhere in the option panel on a working phone.
Apr 22, 2009 | Avaya 4610SW IP Phone
How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Feb 13, 2009 | Avaya 5610 IP Phone
Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Jan 13, 2009 | Avaya 4610SW
Avaya 4610 sw
Are you using any application on your desktop to login or manually from the phone if you are log in through the desktop remove the application and intall it back this should resolve the issue
Sep 11, 2008 | Avaya 4610
I need to lock my ip telephone
Try changing the cor to restricted level with an authcode......
Jul 17, 2008 | Avaya 4602SW IP Phone
Avaya 4602SW IP Phone Logo
499 people viewed this question
Top Avaya Computers & Internet Experts
Thomas F. Schneider
Vincent G
Vincent G
Duncan Mutch
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
