Question about Sharp R-1610 Microwave Oven
The inernal fuse doesn´t hold
My Sharp is R-9H 10. The internal fuse is gone. I tried to change it but when I turn it on its Ok but when trying to use any program the internal fuse will explode. A 10-hamp fuse is not holding, it is necessary to use a 15hamp fuse?
Can someone tell me what is happening or how to get technical support in order to me to this problem fixed please?
  • Sharp Master
  • 9,098 Answers
Apparently you're in the UK where 220V is used, so a 10A fuse would be correct.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
Info on ordering Sharp UK parts / spares is here.
Posted on Aug 21, 2008
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
Sharp microwave oven r-9h20 display flash(00:00)) and no keypress action
On Sharp R-9H-series ovens, when the membrane keypad fails, as in your case, since these parts are no longer available, the oven would have to be retired.
Sorry to bring you bad news. These were great old workhorses.
Sep 04, 2011 | Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
The microwave is absolutely dead as if getting no power - circuit breaker is OK. Died suddenly...just nothing there when tried to use.
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, I have been able to find replacements at Radio Shack. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Jan 03, 2010 | Sharp R-1460 Microwave Oven
Microwave dead
one of 3 things, for sure the internal fuse is gone, then check for a: bad Hi-Voltage;diode, Hi-Voltage capacitor, or the magnetron tube is defective,none are too hard to change out,but the magnetron is fairly expensive to replace:
Sep 22, 2009 | Microwave Ovens
Microwave just stopped working
  • Internal fuse may have opened
  • Door interlock may have failed
  • Magnetron may have failed
  • Control panel may have failed
Jun 19, 2017 | Sharp R-1492 Microwave Oven
Sharp Microwave Oven Corousel
I replied privately to this, stating it may be the HV capacitor, or possibly the magnetron or transformer and giving links.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 31, 2007 | Sharp R-1480 Microwave Oven
first you check all high voltage section circuit and check magnetron .. check control unit also..
Oct 08, 2007 | Sharp R-1610 Microwave Oven
Microwave blew up after cooking an egg
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
Jul 08, 2007 | Sharp R-408J Microwave Oven
Sharp R-1610 Microwave Oven Logo
51 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
