Zenith R57W46 57" Rear Projection Television Logo
David Livings Posted on Aug 21, 2008
Zennox USB Turntable
Hi I am in the middle of transferring my vinyl to cd via the above, however the turntable whilst in the middle of playing a record cut out and now wont do anything, there is power to it and i have tried turning it off to see if it needed cooling down but still nothing.
A
Anonymous
Try the belt it may have come off
A
Anonymous
Send it back----it's faulty
How do I transfer LPs to my iMac/iTunes Library
HARDWARE: You will need a turntable, a phono pre amp, and an analogue to digital converter.
SOFTWARE: You will need software on your computer to take the adigital data stream from the analogue to digital converter (probably via a USB cable) and transfer it into mp3 files on your computer, which can then be saved in iTunes or any other number of digital music platforms.
There are turntable solutions designed to do this. Some have all 3 hardware elements integrated into the turntable, and come with the necessary software on an included cd-rom. I have seen these kits for under $200. Not exactly audiophile grade turntables, mind you, but they will get that one off vinyl of grandpa's barbershop quartet preserved in the digital domain.
I have mislaid the CD that came with my ZENNOX USB Turntable do you know where I can get one
You can try ebay or find the cd files on google to download and burn your own cd
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Zennox usb turntable arm rises before end of record
Hi, we don't have that model turntable in NZ so I can't say exactly where the adjustment for the tone arm lift position is. However on the majority of turntables it will either be beside the base of the tonearm possibly under a rubber grommet or if you remove the rubber platter mat and there is a hole in the platter near the outer edge rotate the platter whilst looking through the hole for a screw near the tonearm. Adjust anti clockwise a little and test. Fine tune until you are happy with where it stops. John. styluscity.com
4helpful
I purchased a Vibe Sound 3 Speed Turntable w/USB to PC and it does not have sound when I plug it in to the USB. The record is spining and I can hear sound from the needle.
The turntable won't make sound on its own when connected to the USB port. There are probably some drivers on the CD packed with the table that you'll need to install, and then you'll need to select the device in the Windows sound control panel. You'll also need some software to record and edit your vinyl if you want to transfer your records to CD.
I'm not familiar with the brand of turntable you have, just the ION, but it probably came bundled with some application on a CD. The ION table comes with Audacity, as well as some trial versions of audio processing (click and pop filter, hiss remover, etc.). Audacity is free, open-source software you can download here if you want it. It allows you to listen to and record your vinyl audio as wave files, then edit it, split tracks, add effects, and other fun things.
2answers
HOW TOTRANSFER FROM CASSETE DECK VIA ION USB TURNTABLE
I'm thinking this is 100% impossible. There is absolutely no way you can get a cassette tape to play on a turntable.
Transferring Vinyl from Kenwood P26 Turntable to PC
Argos has a turntable for 90 pounds which converts Vinyl to MP3 or wave . There are similiar versions for cassette tapes. If you need help finding one. let me know
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
