Question about Intel Motherboard
VGA Port not giving output
My Monitor on Desktop is getting no output from VGA Port. Monitor is working when connected to Laptops
  • 31 Answers
Go into the Bios of your desktop's motherboard. Go to video settings and make sure that video is enabled.
Posted on Aug 22, 2008
How do i get my westinghouse sk 26h730s monitor to work with my HP desktop computer with windows XP?
There should not be a driver required for this. As long as your HP desktop has a VGA video or HDMI video output, you can connect to the back panel of the TV from the video port of the PC. Then, on the remote, select the "PC" option for VGA input, or HDMI for the HDMI 1 or 2 input(s). If the PC only has DVI output, then it is important to know if the output is analog or digital. If it is digital (DVI-D or DVI-DD] then there is no available port on the TV to support it. Using a DVI-VGA adapter on a DVI digital output will not work as there must be a digital-to-analog conversion in order to work.
Sep 01, 2014 | Westinghouse Electric SK-26H730S 26 in....
How to connect com port to VGA monitor?
You need to purchase a pci-e video card and use the pci-e video slot on the mb.
Mar 25, 2014 | Intel Desktop Motherboard DH67CL Media ATX
Monitor won't stay on
how is the monitor connected to the computer? what connection type is the monitor is it VGA or HDMI . What format is the computer video output is it VGA or HDMI. Also you may have two video outputs on the computer. Sometimes the motherboard vga output is disabled so that a much better video plug in card can be used which has its own video output port.
Apr 16, 2013 | Acer America Acer Aspire AX1800-U9002...
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
I can`t use an external monitor connected by VGA port for my Toshiba Satellite M55 S331. I need to know if the port is damaged?
The M55 series does not output to external VGA automatically. You can either go into Setup (press F2 when computer is starting) or use FN F5 in Windows to toggle between LCD, monitor, or simultaneous output.
The monitor port should be standard, so as long as the plug on your monitor doesn't have any bent pins, it should work.
Jul 26, 2011 | Toshiba Satellite M55-S331 Notebook
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
I want to connect a HP w2207 monitor to a HP TouchSmart IQ770 PC. What is the best way to do this?
Your HP w2207 monitor has support for both VGA and DVI inputs. This therefore means that you can connect your HP TouchSmart IQ770 PC via either of these two connectors.
VGA is the blue coloured port on the rear of your monitor.
DVI is the white coloured rectangular port located on the rear of your monitor.
DVI is the better connection of the two as it is a digital connection, so use this one if you can, alternatively you can use the blue coloured VGA cable to connect your monitor to your computer.
It all depends on which output, either DVI or VGA is found on your Computer. Remember VGA is the Blue coloured port and DVI is the blue coloured port.
All the best!
damnor01
Feb 01, 2011 | HP TouchSmart IQ770 PC Desktop
How do i connect my tv to my notebook computer
You get a VGA cable from a local electronics or computer store and connect the laptop vga external monitor port *(its the 15 pin D shaped blue port) to your TV's VGA input *(also a 15 D shaped port).
Then, when you want to watch your computer on your tv. Change your TV input to computer and toggle the laptops video output *(usually by pressing the laptops FN key and one of the function keys that has a picture of a monitor on it simultaneously).
That should do it. And, if you want the picture on both displays the FN feature normally gives you that option if you press the buttons again.
Good luck and enjoy!
May 04, 2010 | Protron PLTV-4250 42 in. LCD Television
How to connect Samsung 40" LCD tothe eMachine desktop T2615. It looks like there is only one connection for a monitor? The computer is about 6 years old.
Older LCD TV's have a variety of inputs, one of them being VGA, to connect to your PC. The problem seems to be that you either connect your PC to its own monitor, OR to the TV, but not both? If that's the case, you may have a couple of alternatives:
The most expedient one would be to get a VGA splitter cable; the other, more expensive: replace your video card with one that has dual outputs: either one with two DVI ports; one with one DVI port and one VGA port; or one with one DVI port and one HDMI port. As you can tell, there are several possibilities, depending on the connectors available on your TV.
Sep 08, 2009 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
136 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
