Question about Pioneer CDJ-1000MKII CD Player
I have a problem with my pioneer cdj 1000mk2. The lights on the unit tend to flicker off and on but the jog wheel still has full control of the music and all the buttons still work to toggle through tracks . do you know what is wrong and how much to fix it cheers
  • adzrienn Aug 21, 2008
    how much does it costs?
  • 68 Answers
Sounds like a fault with the jogwheel that we had before,if you havent had it repaired then you can send it to us to check for you.
thanks.
http://www.audiovisualservices.info/
Posted on Dec 03, 2008
    Problem Solver:
  • 9 Answers
It sounds like something fairly simple if it still works ok, just flickering lights. I have a workshop in SW London. [email protected]
Posted on Aug 21, 2008
6ya staff
SOURCE:
My cdj mk1 jog wheel is stiff when turning an scratchin.
One or more of the bearing wheels have become damaged underneath the jog wheel. You need to strip the unit down and remove the wheel to get access to find the broken / stuck wheels. Replace, or re-seat, and you should be back up and running. The jog wheel is a lot simpler than it looks, once you have it out. Just be careful of the sheet switch, which detects pressure on the wheel. They're very fragile and vulnerable!
Apr 02, 2011 | Pioneer CDJ-1000 CD Player
800 mk 1 plays in cd mode but once vinyl button is pressed play stops. even if I press the play button. The unit still jogs fwd and back just fine in vinyl. The case i use on occasion puts pressure(maybe...
You are almost certainly correct re "pressure switches"
Pioneer call this part "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it, it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one. [email protected]
http://stores.ebay.co.uk/methleykev
Jun 25, 2010 | Pioneer CDJ-800 Turntable
My jog wheel sticks / doesn't glide like it should...
I had the exact same problem. I was working a party when some drunk ******* spilled some beer in my coffin case, thus getting into the jog wheel and cue button. I continued to work with it for a few months but got pretty fed up and brought it to a pio dealer. They fixed it up quick and cheap, now it glides like my other mk3s. I'd say bring it in a get a quick quote.
Mar 31, 2010 | Pioneer CDJ-1000 CD Player
Power problems
Please make sure, power cable and fuse is working good.
Feb 03, 2010 | Pioneer CDJ-1000MK2 Turntable
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Can you help me
Sounds like you have a broken Sheet Switch. Basically, there is a circular piece of plastic which goes underneath the jog wheel, so that when you press the wheel, it activates the switch and stops the track / slows it down, and also puts the indicator on in the middle of the wheel. The part is readily available from Pioneer, and is a bit of a tricky fit, however is not the hardest thing to fit on the unit. However, it is the most fragile part of the player, and most common to fail if the unit has had physical trauma, eg dropping, spillage etc.
Feb 28, 2009 | Pioneer CDJ-800 Turntable
Cdj 800 locking up on vinyl
There are very small wheels underneath the jog wheel, and these wheels are sitting on a plastic assembly, which has a tendency to break over time. More than likely, you'll have to have this repaired by an authorized service technician.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Dec 28, 2008 | Pioneer CDJ-800 Turntable
Cdj mk3 jog
Does the jog wheel lcd light up ?
Regards.
Paul.
Dec 27, 2008 | Pioneer CDJ-1000 CD Player
Pioneer CDJ-1000MKII CD Player Logo
127 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
