Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Bios resets to 07-31-2007 when i turn computer of then back on i resetset it to 08-21-2008
Bios resets its self when i turn computer of then back on on third battery .system brand new .bios sets to 07-31-2007 will not hold new date .08-21-2008 help
  • gopi_rex Aug 26, 2008
    hello, sir
    i have an problem in my that i can't enter into my bios and i can't enter in to mode selection and system is in safe mode now..plz tug me....
In my pc multimedia controller driver can't detect
Posted on Aug 26, 2008
Short the bios pins during power off state.replace the old cmos battery with new one
Posted on Aug 22, 2008
I can no change password not recieving the code to email tried several times
you can reset your password by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
Sep 12, 2014 | Facebook Social Network
My HP Pavilion DV seven laptop turns the power off by it self, sometimes and can only get power when I unplugged and plugged back in the battery but date and time is reset to beginning
When the Date and Time gets reset then this indicates the BIOS battery is flat and cannot keep these settings.
Replace the BIOS battery with a new one and then configure the BIOS Date and Time.
Dec 20, 2011 | Computers & Internet
Hi, I started having problem with my motherboard. First thing happened is: I turn it on the computer->windows update->couldn't go to my start up desk system were frozen. ->reloaded...
Try resetting bios. This is done by a small jumper on most modern boards. location on your board. Try resetting bios. This is done by a small jumper on most modern boards. See image for the location on your model. Simply take the jumper (it is the plastic piece on two metal prongs. Move it so that it is on the middle and opposite prongs. to be sure of the reset start and after a 5 count turn off your pc. Move the jumper to its original position. This should allow you access to bios. nathan_f_0.jpg
May 14, 2011 | ECS 945P-A (V3.0) Motherboard
I cant locate my bios on my laptop how do i reset it? when it start it does not load the bios setting i want to reset it.
To answer this question for you I will need a few pieces of information:
  1. What Computer vendor manufactured your computer? What model? (Eg: Dell Latitude D830)
  2. Roughly what year was it built?
  3. What specifically in the BIOS would you like to reset? Or you just want to set everything back to the default settings?
  4. If you get detailed POST (Power-on Self Test) results when you start up the computer, can you check and see if it tells you the BIOS Manufacturer? (Some common ones are Phoenix, Award, AMI, etc)
Every motherboard has a certain key or key-combo you can press to access the BIOS. Sometimes it is not very obvious and other times they print the key/combo on screen as the computer starts up.
May 12, 2011 | Computers & Internet
Computer powers up by its self when first plugged in
Most BIOSes have a setting for what to do after a power failure--stay off, turn on, resume last state. If the user is unplugging the unit before a total legal and proper shutdown, then that might explain why it turns on 'when plugged in'. Disconnecting before completely shut down is detected by the BIOS as a power failure.
Also, killing power to a running system can cause file table corruption, corrupt files, a destroyed operating system, even in rare cases a total loss of everything on the disk.Although, If you mean the computer turns on by its self after it's been turned off (so he unplugs it to keep it from powering on), then it might be "auto awake" settings in the bios, I've seen some bios' have "auto-power on" settings so that signals from network cards or peripherals can power the computer up.
Also It turns out the CMOS battery went out and that probably reset the BIOS so the computer itself was set to turn on by itself when it was plugged in. With a new CMOS battery and a quick setting change the computer is ready to go.
Dec 27, 2010 | Gateway 310 S PC Desktop
My hp womt start up the quixk start lighta cpme on then notging
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance.
Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset, some devices are often overlooked.
Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.
If the computer can access part of the memory, it may be possible to access the BIOS Setup Utility display and perform a memory self test to identify other memory issues. If the computer cannot boot to the BIOS Utility, try removing and reseating the memory and the hard drive, and then repeat the following steps to perform the memory self test.
  1. Plug the AC adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. In the BIOS Setup Utility, use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Diagnostics .
  5. Use the Up Arrow or Down Arrow keys to select Memory Test .
  6. Press Enter , and then Yes to perform memory test.
  7. After test completes, press f10 to Save and Exit , and then press Enter to Exit Saving Changes? .
Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. Use the steps below to test the hard drive in a computer using the HP Hard Drive Self Test.
Plug the AC Adapter into the computer.
Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup Menu.
Use the Left Arrow or Right Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
Turn off the computer and wait 5 seconds. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  • Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
  • NOTE: The exact wording of the option for your particular BIOS may be slightly different.
    1. If Windows does not start properly, reset the BIOS to the default settings. Using the default settings, you should be able to boot into Safe Mode and install the latest BIOS. To reset the BIOS, press the power button to start the computer and repeatedly press the f10 to enter the BIOS setup, then press f9 key to Reset BIOS Default . For more information, refer to the HP Notebook PCs - Configuring the Boot Order in the System BIOS support document.
    2. If it will not boot to the BIOS, you may need to remove and re-seat the hard drive. Instructions may vary depending on the notebook model you are using. For specific instructions on re-seating the hard drive in the notebook, refer to the HP Notebook PCs - Steps for Removing and Replacing the Hard Drive support document.
    3. After re-seating the hard drive,perform a hard drive reset.
    Nov 16, 2010 | HP Pavilion dv6000z Notebook
    Need to reset bios password
    Inorder to reset the BIOS password, you have to open the laptop from the back, locate the CMOS battery, remove it and press down the terminal (with the help of a screw driver) for 5 sec, now turn ON the computer (keepon holding the terminal) short the BIOS. Now, Turn off the computer and restart the computer, it will reset the BIOS password.
    Thanks and regards,
    Anil.B.R
    Sep 27, 2010 | Toshiba Satellite 2400-S251 Notebook
    I open the intrusion selector by pulling out jumper then turn on computer then bios says system tampered i turn it off then put jumper again and set bios to default but my computer not responding to...
    There is a jumper that resets the bios clock password etc...etc
    You need to locate it 3 pin set 1 jumper and look for <norm/reset> in small white print.
    Self explanitory
    Aug 23, 2010 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
    I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
    if you still have old video card remove the new one and replace with old one
    change setting back in bios
    then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
    please let me know
    May 03, 2009 | Computers & Internet
    Bios set 08-08-2008 resets to 31-07-2007 every time i turn computer off.turn computer off then turn on it resets its self to 2007.turn power off and on at power switch. computer starts on own i do not push...
    - do a bios update (or downgrade if needed) to see if it fixes the issue
    - but probably the BIOS battery is not keeping the proper voltage anymore, and it automatically resets the BIOS (do the bios setting that u change, remain changed after unpluging/pluging the comp ?!). Try keeping the computer pluged in for a day and see if the battery charged properrly (if the set date remains )... if not ..change the battery.
    - as for the self starting, there is a setting in the BIOS, that activates/dissables that ! - see u;re user manual ...
    Aug 08, 2008 | Computers & Internet
    Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
    107 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
