Question about Logitech Webcam
Logitech webcam not working
I have installed my logitech webcam on my computer but when i plug it in is comes up in a window thing, Files Need, The file 'usbccgp.sys' on windows XP Home Edition Service Pack 2 CD is needed. At the bottom it has ' copy files from:' then the address bar thing. It has 'c:\program files\common files\logitech\qcdrv\winall\msgr\i386' in the bar but when i click OK it just beeps and the window stays ther... any ideas?
much appreciated
steve
    Sergeant:
    Novelist:
  • 166 Answers
Steve go here
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
look for yor camera model, click download software then choose your operating system on the next page that will give you the logitech software that you need to install to fix your issue
Hope that helps
Posted on Aug 24, 2008
Missing Usbccgp.sys
What is usbccgp.sys?
Microsoft USB generic printer driver system driver file. This usbccgp.sys file is safe and should not be considered threat to your computer.
Download this update from this link and install:
http://support.microsoft.com/kb/814560
Otherwise uninstall and reinstall the printer driver (if you have any) on your PC.
Sep 23, 2012 | Computers & Internet
How to to instal logitech webcam
Logitech webcam usually comes with a CD to install software and drivers. If you are using windows 7 your computer should recognize Logitech Webcam when you connect it to your computer's USB port! Its necessary to have internet connection for your computer and Logitech webcam is just plug and play that means!
Just connect the webcam to your computer and remaining is done automatically!
Also drivers for logitech webcam are available online at their site www.logitech.com
good luck!
Sep 11, 2011 | Logitech Computers & Internet
I want to install my camera
For new webcam no drivers are needed . If not working, we need to install the driver . you can download for quickcam from logitech website http://www.logitech.com/en-sg/webcam-communications/webcams
Jun 13, 2011 | Logitech QuickCam Express Web Camera
I have no instructions on how to set up the webcam to my desktop computer. I dont know the serial number nor the model number . the only thing I see on the wires are these numbers p/n b61050-0050 and also...
Hey Dont worry most logitech's are plug and play systems. Meaning you plugit in and windows installs the driver automatically. If you have windows Vista or windows 7, plug it in, then go to windows update and check for new updates. The Driver will be located in an option update. Select it and install it.
May 07, 2011 | Logitech Webcam
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
Just need a driver for this logitech webcam # 861194 0000 and I've been trying to find one for months. Can you please make things simple and point me in the right direction please. Barb
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
In addition to the Logitech installer you will need to check the support software - Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click 'Start', click 'Run', type dxdiag in the Open box, and then click OK
Run through the tabs checking the 'notes' windows for information
The version will be shown on the 'Systems' tab
Procedure to re-install Logitech software
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options during the installation - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
Dec 10, 2010 | Logitech Webcam
I bought a web cam. How do I install it?
Some webcam models are plug and play.
It would have been good, if you mentioned the Operating System on the computer (Windows XP , Vista , Windows 7 : 32 bit / 64 bit), as well as the exact model of the Logitech Webcam.
The Logitech Webcam may have come along with a disk for the driver(s) : i.e : it's software(s).
Or, you may install it's drivers from the Logitech website, by clicking on the foll. link :-
http://www.logitech.com/en-in/support-downloads
Over there, you have an option to select the Logitech Webcam's model & the Operating System on the computer, and you can install the drivers from there.
Since you will be using Skype, make sure that on Skype, under video settings, the Logitech Webcam is selected.
I hope the above details do suffice.
Oct 07, 2010 | Logitech Quickcam Chat Webcam
I lost my installation Cd and I cannot be able to install the webcam in my Computer............. that is the problem I am I have now with Logitech Quickcam. Please I need a link where I can be able to...
Restart computer
Sep 23, 2010 | Logitech QuickCam Communicate Deluxe...
I have a logitech messenger webcam 8.47 which used to work. I am running windows XP. I noticed that it stopped working this past week, thinking it wasn't plugged in properly, I unplugged it and replugged...
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
Set your webcam mic as default ( if it has a built in mic)
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Sep 10, 2010 | Logitech Webcam
My logitech webcam isnt working everytime i click on it and press take a picture i just freezes and shuts the logitch web camera off!!!
Restart computer
Sep 05, 2010 | Logitech Webcam
Logitech Webcam Logo
143 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
