Question about Vacuums
Miele S271i My vacuum refuses to start. Is there a fuse in there somewhere and if so, how do I get into the thing! Sounds silly but I can't find a way into the engine room.
4 Suggested Answers
  • 10865 Answers
SOURCE: Miele vacuum dust problem
Hello. The problem you are having can be rectified with the new Miele FJM bags.
http://www.mielevacuumbags.us/
Also, if you have never taken your machine into a vacuum repair shop for an internal cleaning, please do so. J.
Posted on May 24, 2010
  • 52 Answers
SOURCE: Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
Posted on Jun 06, 2010
  • 52 Answers
SOURCE: Miele Red Star, small spark at outlet, no power to vacuum
The vacuum has a standard tube internal fuse. If you are lucky that is all it is. See the site http://www.sannerud.com/house/miele.html for instructions on how to open it up.
hope that helps
Posted on Aug 11, 2010
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
MIELE Silver moon turns off after about 10 minutes of using. If I press the "+" button on the handle, it'll turn on again and start up again. Is this an overheat thing or a hose thing?
That sounds like a hose issue, but to make sure it's not an overheat issue I would recommend ensuring that the hose, wand, and dirt tube through the power-head are all clear and free of obstruction. Also try raising the height adjust on your power head: if you have it set too low, air can't move through the carpeting and therefore it will overheat the motor and also not clean as effectively as it could. If all of these things check out, you will have to replace the hose with an SES-125A, but once you've done this you will not have the issue again. Cheers! -R
Aug 03, 2011 | Miele s558 Silver Moon Vacuum
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
No suction - goes to red alert even with a new bag
sounds like its blocked in pipe somewhere take hose of and push something like a long brush handle through the pipe if there's anything in there it will get pushed out
Jun 26, 2010 | Miele s558 Silver Moon Vacuum
hope that helps
Jun 05, 2010 | Miele Red Star Bagged Canister Vacuum
The Miele S251i just stopped working. Is there an
How long has unit been down? There is a inline fuse by motor housing internally in unit, but sometimes these units take awhile for them to reset
Dec 03, 2009 | Miele S251i Plus Bagged Canister Vacuum
My vacuum over heated, the warning light has come on a the filters changed but it still refuses to reset and turn back on, any suggestions?
Could be fuse line! Estimated cost of repair $39-59.00 with 1yr warranty
Shipped USPS is very cheap and with our service it still beats many!!!!
Nov 23, 2009 | Miele Cat & Dog 326i Bagged Canister...
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
My dyson works only without the prefilter
Dyson's are terrible vacuums. Sure they look cool and may work for a couple months but they start to "fall apart" no more than a year. If you have pets, then i suggest you spend the money on a machine that won't break down or give you silly issues like a Dyson would. This vacuum is called a Miele Cat & Dog.
http://www.thinkvacuums.com/miele/catdog.htm
Jul 27, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
