Question about Maytag Neptune MAH7500WH Front Load Washer
The washer(MAH7500WH)doesn't work
This is a used washer,someone gave to me,and power and water ok, But it doesn't work after i push start bottom,the display panel nothing happen.Could be i don't know how to use it? Thanks
  • 639 Answers
ngafm1 at your service,
Below is the site to get and download the user manual for your
Model MAH7500WH Washer
Maytag is owned now by whirlpool and that's why the web site says Whirlpool below!
Bless you,
Please give me the best rating here
at fixya. com before you sign off!
Thank You
Posted on Sep 04, 2008
Electric Pressure washer hums but does not work.
guess is that someone started it without water...and seized the piston. You can try spraying silicon spray into the water intake (lots of it) and then see if that frees the piston. You can start it for a moment without water after spraying silicon into the intake. The alternate ( not recommented) is to open the pump housing and spraying directly into the piston to free it up.... Good luck.
May 16, 2014 | Greenworks 1600 PSI 1.3 GPM Electric...
F21 code displayed> cleaned water trap next to water pump that had lots of stuff plugging the filter but now power cord GFCI plug shuts off when I try to Start washer...
Hi you could have a clogged drain pump or obstruction in it. Remove the lower bottom cover. Have a container or towels to catch water. Removed the drain cover by turning counter clock wise. Sometimes you have to remove the pump to fully and clean. You also need to plug the washer into another outlet. If possible use an extension cord use the extension for test only.
Apr 25, 2014 | Whirlpool Duet WFW9550 Front Load Washer...
My maytag Neptune washer mah7500 panel doesn't light up, but still works
Thought it was the door switch/grounding issues/loose wire, etc. Finally found that there was a bad capacitor on the circuit board. It was a 15 cent part that, when replaced, caused all the non-start/power failure indication issues to go away. I've included a picture of the bad part - you can see the slight bulge on the top of the capacitor and a little leakage. Hope this helps. 650c7b72-0a6b-4fe3-b776-b4d9dc5589c2.jpg
Feb 01, 2013 | Maytag Neptune MAH7500WH Front Load Washer
"GE Quality Product Spacemaker Laundry"
you could have a broken belt or a frozen pump pulley. the leak has to be addressed to see where it's coming from. it could be from the pump hoses/connections. it could be the main tub seal that's leaking. if you're not handy with tools and test equipment, i suggest you call someone to have a look at it. these are problems that wont be resolved by pushing a button.
and thankyou for using this site. i hope you will continue to use this site.
if you have any further quesions or need further advice, repost another question. be sure to include the model number as well. you gave a good explanation, and that helps. anything you can think of can be of assistance
Jul 07, 2011 | GE Spacemaker Washer and Dryer Electric...
My windsheild washer fluid dont work. how do i fix it
remove the small plastic hose for the washers and press the switch to turn them on, if there is water coming through the hose your spray holes are blocked on the wiper arms or the bonnet, wherever they are situated
If there is no water coming through, check for power at the connection for the washer pump, you will have to get someone to press the button or switch and hold it while you test for any power to the pump motor
If there is power there then the pump is faulty, replace the pump and test
the pump is located on the bottom of the washer fluid resevoir, some just push into a rubber seal, if that is the case just pull it out and replace it with the new pump
Jul 03, 2010 | 1996 Nissan Pathfinder
Lack of water pressure from gun
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up. Also, adjust the nozzle by turning it to increase pressure.
Apr 15, 2010 | Karcher PSI Electric Pressure Washer
The water thing of the windshields is not working, I already tried putting a pin through the hole to see if it was clogged, and I checked the water thing at the front and its full. What else can I do?
have someone hold down the washer stalk to activate and listen, if its not spinning to squirt water then you may need a new pump, or the switch on the column.
Jul 16, 2009 | 2002 Kia Rio
Hotpoint WD860P - F5 error
Remove lower rear cover of washer, locate and remove large black hose to bottom of tub.
Remove and clean plastic filter located in the hose, check pump for blockage, refit filter and hose , and test for leaks.
Plz rate my solution.
Jan 22, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Control board
have you the touch onsole first to se if it was ok there have been more problems with tha then the cpu board? do you get any beeps while touching it??
Aug 23, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
126 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
