Question about RCA R56WH76 Projection Television
R56WH78 convergence problem
The image on my screen is like a 3-D movie without the glasses, 3 images each of red, yellow and blue. I thought to reset the convergence but found that it is gone from the menu. this may be a common problem as the local TV repair shop has repaired one with the same problem but they are unwilling to offer me advice. is this something that I can fix myself? I am a auto mechanic who specializes in computer controls. I have the same problem w/convergence but I also have another problem as well. I had been having probems with my home electricity and I think it messed up my wifes and I laptop power cables, and I had to order another tivo dvr. I am wondering should I replace the power module as well??
Thanks
  • RCA Master
  • 6,487 Answers
Yes replacing the power module will help a lot , Since you have background with computer and some electronics you should be able to fix this by your self you may just need to solder some loosen parts of your television then that should fix it...
Good luck.........
Posted on Aug 21, 2008
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Get a new TV , i have had problems every year and now its off warranty, I will never buy an RCA again as long as I live,
May 13, 2008 | RCA R56WH76 Projection Television
Akai pt5598hdix convergence problem.
go to the following link and click the contact link on the lower left side and tell them your model they will email you with the correct convergence ICs that you need for your model. they also provide free installation instructions with pictures and free tech support when you order the replacement ICs.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | Akai PT5598HD 55" Rear Projection...
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Convergence Problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Convergence Problem
replace convergence ic
Oct 16, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Open Questions:
RCA R56WH76 Projection Television Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
