Question about Asko Washing Machines
Hi, I have a Asko W6221 washing machine. It is about 6 years old. Just recently it has started to leak water/washing detergent down the front of the machine, from the gap that is located underneath the detergent draw. It does this at the beginning of a wash cycle. At first I thought I was using too much powder or that it might of been the detergent/ powder that I was using. I have reduced and changed my powders / detergents and the problem still continues. What do you suggest?
  • koel145 Aug 21, 2008
    Hi thanks for the solutions. Will give them a try. Thanks
    Master:
  • 848 Answers
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Posted on Aug 21, 2008
Asko 6221 washer. push start button and here the click but the washer does not fill. Cleaned coin trap and cleared a dime from one of the lines
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Asko W6221 Front Load Washer
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Not getting enough water
hi yes it sound like the valve is faulty,or the tap.
Jun 08, 2010 | Asko W6221 Front Load Washer
To little water?????
I DID SEARCH ALL OVER AND THIS THE MANUAL I FOUND FOR YOU :) HOP IT WILL HELP ...
http://194.14.129.136/brandsite/DocumentOpen.aspx?did=3878&mid=43&lid=2
Sep 22, 2009 | Asko W6221 Front Load Washer
Asko w6221 washer won't start
first I would check you drain pump ... make sure it is clear and clean.. next if you have a meter be sure it is getting power and that it is not shorted ...if it is not getting power then I would check the wires first then check your control.
Hope it helps if Not let me know more about you problem..I can help
Aug 02, 2009 | Asko W6221 Front Load Washer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Jan 24, 2008 | Asko W6221 Front Load Washer
Detergent not being washed out of dispenser
This suggestion is not too good. If your dispenser opens at the initial stages of the cycle, just a little - pour some water into the dispenser to wash down the detergent. (For my machine i can pull out the dispenser anytime during the wash, except when water comes into the dispenser, but even then i think the water enters the tub.) For this you dont have to hang around the machine for long for it is in the initial stages of the cycle. Later you hv to check the flow of water into the dispenser. Hv no idea how to do it; but i gave you a quick solution.
Mar 01, 2007 | Asko W6021 Front Load Washer
Machine drains and dial turns directly to S after filling with water.
moe thasn likly you have a pressure switch that is either telling the machine its too full and making it drain or its not seeing the switch and so it drains. Another possibility ids the machine is leaking. Pull the lower cover off and make sure there is no water in the bottom. These askos have a float switch down there that will run the drain if the sense water leaking into the lower tray. Last but not least, you could have a bad timer. these timers are covered for 5 years (parts only) from date of installation. The first 4 digits of the serial # will tell yuo when the machine was made the firts 2 are the year and the second 2 are the week of that year (so a serial beginning in 0145 woul;d mean built in the 45th week of 2001 and so on. Good luck!
Sep 26, 2006 | Asko W6221 Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
