Question about HP Compaq nc6000 Notebook
Keyboard I have problem with left control ctrl as chort key.
    Problem Solver:
  • 11 Answers
Change a keyboard,the problem can solve .
http://www.it-battery.com/laptop-keyboards-c-180.html
Low price, high quality and special designed for your laptop. If you could not find the suitable laptop keyboard for your laptops, pls email us with your laptop model and your original laptop keyboard's part number
Just go to www.it-battery.com.
Posted on Sep 05, 2009
  • 294 Answers
Boss U got a problem.. need to see a customer care.. if its under warranty they'll solve it for free.. if not u got to pay for it..
Posted on Jul 25, 2009
How do I get the question mark punctuation to work...
When you were typing something you probably hit the left shift key along with ctrl. Hold down the left shift and ctrl for about 2-4 seconds and you should get your question mark back.
To make it so it never happens again, go to control panel / region and language / keyboards and languages / change keyboards. Remove every language except for English (us) or whatever region you want to use. Before you accept verify that your keyboard is on your preferred language before you do this. check and make sure you are getting the proper slash when you push slash, to change it if you're not getting the slash use the (left ctrl + left shift for 3-4 seconds) if that doesn't work then try alt and left shift.
Sep 13, 2014 | Lenovo Keyboard
Cant use shortcut keys on lycosa
you should turn off gaming mode of the keyboard . if you have razed snap case downloaded in your computer go to manage gaming mode off
Oct 11, 2012 | Razer Lycosa Gaming Keyboard
Letter between c and b wont work! its the paste code key also and I dont recall using it to paste anything Whmat's your problem?
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
Sep 20, 2011 | Microsoft Comfort Curve 2000 Keyboard
Where is my Dell computers Command key?
The Command Key is only found in Mac computers. It gives shortcuts to common commands by using the keyboard. The Control Key (CTRL) gives the same function in Windows computers. Therefore, the Command Key on Dell computers or any other windows-based computer is the Control Key (CTRL).
For Example...
  1. CTRL + C = Copy
  2. CTRL + V = Paste
  3. CTRL + S = Save
  4. CTRL + X = Cut
  5. CTRL + Shift Key + S = Save As
Mar 06, 2011 | Computers & Internet
I have a Compaq Presario Model CQ5521F, The keyboard, how do I use the blue letters or turn them off, Keyboard P/N 505130-DB1, S/N LEO1530057. Thank you Doug
You must press and hold the little Fn button usually in the lower left hand corner next to Ctrl and the Windows Logo key along with the key you wish to use.
Mar 01, 2011 | Computers & Internet
Is there any way to make Fn key working as Ctrl, and Ctrl as Fn? I just want Ctrl key to be at bottom left corner of my keyboard.
You can download a software "Keytweak", which would help you in remapping the keys in the keyboard, so with the help of key tweak you can swap the Fn and the Ctrl Key.
Oct 29, 2010 | Acer NSK8458AN Keyboard
How can i disable my verr.maj. on my acer laptop?thnk you
Hi!
This problem occurs when you inadvertently switch the language of your keyboard by simultaneously holding down the left 'ctrl' key and the left 'shift' key for 3-4 seconds.
To resolve:
Press 'ctrl' on the left side simultaneously with the left 'shift' button for 3-4 seconds; this will switch your keyboard language up to the next in queue. Keep doing this until you get the desired one (i.e. english US or whichever keyboard of preference that you have selected).
If you plan on only typing with only one type of keyboard, then you can disable the above ctrl-shift hotkey sequence and avoid this problem in the future. The instructions to do this are as follows:
1. Go to: control panel --> clock, language and region --> region and language --> keyboard and language tab --> change keyboard --> advanced key setting tab
2. Select/highlight 'between input languages'
3. click 'change key sequence'
4. Under 'switch keyboard layout' select 'not assigned'.
5. click 'ok'
6. click 'ok'
Hope that helps!
Sep 26, 2010 | Computers & Internet
Can you tell me what the shift key looks like
Is is normally located on the left side of the keyboard just above the control (Ctrl) key. It may say Shift or it may just have a big "up" arrow.
There is also one on the right side of the keyboard just below the "enter" key and above the Ctrl key.
Jan 19, 2009 | Logitech (967217-0104) (9672170104N)
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
HP Compaq nc6000 Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
