Question about Microsoft Windows 98 for PC
Win98 By using which command i can see the serial key of win98 at command prompt?
  • 33 Answers
This maybe the one you need.
http://www.goextranet.com/HowDoI/CDkey.htm
good lucK!!!!
dont forget to rate this post
Posted on Aug 21, 2008
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
Need serial number
If running Windows you can find you serial number via the Windows Command Line Interface (CLI)
HowTo:
Start --> Run --> CMD --> OK
at the ">" prompt type: WMIC BIOS get serialnumber
Notes and Tips:
Help! I don't see the Run Command at the Base Right of my Start Menu
Select the Windows Key 5efscqsiutc36pracwwi8vi8xg8fotfo1h4qiww+19xaygba7ieowaaaabjru5erkjggg== plus R together on the Keyboard
This will launch the "run" box , type in CMD {short for "command"} and click OK
now at the ">" prompt type: WMIC BIOS get serialnumber
and the return result is your machine serial number.
May 07, 2011 | Computers & Internet
My computer is stuck in Safe Mode. How do I get out???
What Windows version are you using? You may be able to restore a previous registry if you are using Win98 or WinME.
This thread really belongs in the appropriate OS forum
Also verify that you are actually in safe mode and not just looking at a standard VGA screen. When you start up, does it actually say "safe mode" in the 4 corners and ask you to "ok" it?
If you are not actually in safe mode, try going to Display Settings and resetting your resolution and color depth. If that doesn't work, you may need to reinstall your video drivers, however reinstalling a previous registry often works for the problem.
Try holding the ctrl key down starting up if you have Win98. Choose the "command prompt" option if available. At the c:\> prompt enter:
scanreg /restore
use the arrow keys to select a prior started registry.
If you have WinME, use your WinME startup disk and select "minimal boot"; at the a:\> prompt enter scanreg /restore
Aug 26, 2010 | Microsoft Windows XP Home Edition
I lost the serial number for windows 98. When I recovered the drive it won't proceed to run Windows 98 without the serial number. How do I recover this or bypass it?
If your Win98 can boot to windows, your can use the "nirsoft produkey" to locate your Win98 Keys located here
If not, do a clean install with this KEY:
HQ6K2-QPC42-3HWDM-BF4KJ-W4XWJ
Jul 19, 2010 | Microsoft Windows 98 for PC
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Feb 02, 2010 | Zebra LP 2844 Thermal Printer
Need to restore windows 98 have no cd
You can download boot and recovery CD's from allbootdisks.com
Aug 31, 2009 | HP Computers & Internet
Sir, this is jafer i forget my acer laptop bios password
To clear BIOS password!!!!
You can use following command in command prompt.
c:>debug (You will see -)
- o 70 2e (Just simply type o 70 2e)
- o 71 ff
- Q
This will work on most DOS version.
I already tested this command in win98.
o mean open the address.
This doesn't work on bios system password. Just only for bios password.
Jan 13, 2009 | Computers & Internet
Windows98 hp
if there is a dump of win98 in the drive c of your laptop
the go on command prompt
c:\>cd win98 Enter
c:\win98>setup Enter
and repair the win98 without any loss of data
second install antivirus and update properly the scan al the system
Mar 14, 2008 | Acer Aspire 5050-3242 Notebook
Serial code to install windows 98
Windows 98 Serial Code will be present at the Back of the CD package cover along with the Universal Bar code. i have 2 pirated serial key for windows 98. have a try with this keys hq6k2 qpc42 3hwdm bf4kj w4xwj and
tmv73 8vyg6 tyctr trd6k yv9pw
Nov 11, 2007 | Microsoft Windows 98 for PC
Serial number of windows 98
the s>n for windows 98 is :
KYFCR-98MMC-CJVKM-9H33T-VVGDB
or
win98: m34Gj-9b4R3-ck3bw-m7mk3-9wvGy
2-
win98: PDXVM-3QGHD-7PF4D-28WQR-3WBW3
3-
win98 :pdxvm-3qghd-7pf4d-28wqr-3wbw3
4-
win98 :KVBHH-2VG4T-D2JRQ-TXVM7-QXWTT
and you welcom
bay
nevo
Nov 06, 2007 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
