Question about HP Office Equipment & Supplies
In pop up window it tells me colour cartridge error remove and check which i have done to no avail. also on comp screen tells me cart error. Have tried to press set up nothing happens. Also have a red light flashing under the cancel button. When i press cancel nothing happens. Cannot do anything. Have turned off and on several times, just comes straight back to error message.
  • 25 Answers
Make sure the cartiages are sitting tightly in the printer and isn't loose. There are contacts on the cartiages and if the contacts aren't touching the ones properly in the printer it will show that cartiages aren't there.
Posted on Aug 21, 2008
My lexmark x 5650 keeps saying alignment error, try to remove tape. I've done this multiple times, tried cleaning the cartridge, and it keeps saying alignment problem. ive unplugged and plugged back in...
alignment error usually means that one cartridge is not printing, or paper tray is empty.
try removing both cartridges then stamp each printhead on some folded tissue paper. You should get one solid strip of black ink with the black cart and 3 colour strips with the colour cart.
If you don't...there is your problem.
good luck
LC1000
www.inkbank.com.au
Dec 01, 2010 | Office Equipment & Supplies
Very slow operation, misleading info. re. colour cartridge
hi,
Can you please give the make and model no. of your printer
Jul 29, 2008 | Office Equipment & Supplies
My HP Officejet 5610 All-In-One InkJet Printer keeps randomly popping up with cartridge error. Take the out then reinsert to no avail. changed with new. still keeps popping up
If the "new" cartridges were brand new HP oem cartridges, there are two things I would do. First, take out the cartridges and inspect the contact area (where the electrical in the printer meets the electrical on the cartridge) and make sure there is no dirt or ink on the contacts. Secondly, remove both of the cartridges, close the lid, and pull out the power cord while the printer is on. Wait at least 10 minutes, plug in, power up and wait until it is done making noises. Open the lid and insert the black cartridge first(important!) and then the color. If this doesn't take care of the issue, replace the printer. (If you're sure the carts were brand-new)
Sep 29, 2010 | HP Officejet 5610 All-In-One InkJet...
MY HP PHOTOSMART C4180 PRINTER HAS A WINDOW THAT IS DISPLAYING THE FOLLOWING MSG: "INK CARTRIDGE PROBLEM. REMOVE AND CHECK CARTRIDGE ON RIGHT. REFER TO PRINTER DOCUMENTATION." IF I WAS OUT OF INK OR...
the cartridge print heat element is shorted, have fixed dozens of these with the same message, it is always the cartridge, this is also very common on carts that have been refilled more than 3 times,the grid wears out and shorts and that pops the message u see.
Aug 02, 2010 | Office Equipment & Supplies
Managed to get rid of error 1203 message. Now repeatedly getting install colour cartridge into righthand side. I've done this (repeatedly) but it's not recognising the cartridge
It could be Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jun 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
Canon PIXMA IP6210D will not recognize cartridges
Cartridges have smart chips in them to prevent refilling and they tell tales if you do. There are some suggesitons in the link for resetting.
Canon PIXMA IP6210D will not recognize cartridges Google Search
Mar 17, 2017 | Canon Pixma iP6210D InkJet Photo Printer
Installed new colored ink and keeps saying " remove and check colored ink"
The cartridges comes with the protect tape at the bottom please its removed, if removed please clean the copper contacts with dry tissue , if you get the same error try the old cart if you get the same error the printer is faulty or if dont get then the colour cart is defective get it exchange if you had brought original cart as it comes with 6 months warranty...............
Jun 03, 2008 | HP Office Equipment & Supplies
MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Mar 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Fatal Error 17H - toner cartridges will not advance
Open the front door and remove the toner bottle.
Look near the colour toner carts and you will see a small round hole. Jam a screwdriver in that hole and the carousel will rotate freely. Move the carousel round and remove each toner one at a time.
Oct 10, 2007 | Konica Minolta magicolor 2300DL Laser...
55 people viewed this question
Seeker5211
Seeker5211
