Question about Microsoft SQL Server 2000 Standard Edition for PC
UPDATE DATA WINDOW IN PB 11 ERROR
SQLSTATE = 22001 ERROR COMES WHILE UPDATING TABLE OF MS SQL 2000
  • hmnaguib Oct 06, 2008
    I have the same problem
    Problem Solver:
  • 6 Answers
It is probably a string column, being updated with a longer string than it can contain.
Date time columns may also cause this.
If you know the exact SQL update statement you can send it here.
If not, you may consider trapping it with Profiler.
*********CAUTION - if you have a production server with multiple customers depending on its availability, do not try profiler without guidence ********************
If you are the programmer, we may consider changing the field type or truncating the string, acording to the applicational needs.
Posted on Dec 21, 2008
Repair database without being attached SQL 2005
Use SQL Server Repair Kit. A convenient, reliable and ultimately efficient MS SQL database repair tool for system administrators, developers and database experts. Best in class performance and outstanding usability for users with and without experience.
Read more: http://www.mssqlserver.repair/
May 13, 2015 | Microsoft SQL Server 2005 Enterprise...
How to fix mySQL corrupt databases?
you should follow two steps:
Create an appropriately named database on the target machine
Load the file using the mysql command:
$ mysql -u [uname] -p[pass] [db_to_restore] < [backupfile.sql]
Have a look how you can restore your tut_backup.sql file to the Tutorials database.
$ mysql -u root -p Tutorials < tut_backup.sql
To restore compressed backup files you can do the following:
gunzip < [backupfile.sql.gz] ' mysql -u [uname] -p[pass] [dbname]
If you need to restore a database that already exists, you'll need to use mysqlimport
command. The syntax for mysqlimport is as follows:
mysqlimport -u [uname] -p[pass] [dbname] [backupfile.sql]
Or make use of Repair Toolbox for MySQL
Demo version is here-: http://www.sql.repairtoolbox.com/
Feb 08, 2015 | Microsoft SQL Server 2000 Standard Edition...
Recover data from corrupt .mdf and .ldf files.
You can find more information here:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Open your SQL Server Management Studio console. This application shortcut is available in the SQL Server directory in the Windows Start button.
· Enter the system administrator user name and password. SQL Server's administrator user name is "sa." This account is required for privileges to restore the database. If your restoring on a host provider server, use the administrator user name and password they supplied for your account.
·Right-click your database name and select "Attach." In the new window that opens, click the "Add" button to open a dialog box.
·Select your MDF file and press the "Ok" button. It may take several minutes to restore the database if it is a large file. Once the process is finished, browse your tables to verify the data. The database is now restored.
If nothing helped try to use:SQL Server Fix Toolbox
http://www.fixsqldatabase.com/
Nov 28, 2014 | Microsoft SQL Server 2000 Standard Edition...
How to recover SQL server mdf files?
RecoveryFix for SQL database recovery software is recover and repair MDF files components from corrupted SQL server database. This software compatible with Windows 7, Server 2008, Vista, Server 2003, XP and 2000. More details see this site: http://www.en.repairsqlserver.net/ or download this tool from http://www.en.repairsqlserver.net/free-trial.html
May 06, 2014 | Microsoft Database Software A5K-02817 SQL...
I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Regards
GeWiz.
Jun 16, 2009 | Microsoft Visual Basic Enterprise Edition...
After installing DB2 query is not executing
could you check whether you are connected to the database, where you are trying to create table,
check the database list, then connect to the database you want then execute the table creation ddl,
if no db found then create a database then proceed.
Dec 05, 2008 | IBM DB2 Connect Enterprise Edition for PC,...
I installed DB2 in my laptop . then i go to all programs->DBCOPY1(default)-> command line tools -> command editor then write down query to create a table but i cant build it it is showing CREATE TABLE...
Before you create a table you need to:-
1. create a database
2. create a username and password or use the admin generated userid
3. connect to the database
you can then create a table and use the database
Please post if you do not know how to do this and i'll give you some links
Table not gettin updated
Generally database updates either require a commit to have the database perform the appropriate checking and actually flag the rows as part of the database. That Commit can occur in two ways -- some databases can be setup with an auto commit or auto rollback when the database is disconnected. The first means the programmer needs to do nothing. The second means if the programmer does not commit the updates are backed out of the database. To commit is generally considered bad because if there are any data errors partial transactions and logically inconsistent contents can exist in a database. For example entering an order for merchandise requires a single header row to identify the customer and multiple items rows to indicate what was ordered. If the third item record added to an order had an error and the application did not rollback and the database auto committed and incomplete order with only two items would be saved in the database. Traditionally databases with an automatic action at shutdown are set to rollback to assure such partial information is not saved. Even with auto rollback good programs detect errors and rollback themselves and allow users to continue.
The net result of the above is the probability that if the inserts actually occurred as you believe the there was a missing commit to confirm their addition to the database. and an automated rollback kept them from being completely added to the database. Another alternative is that the insert was not error checked in the program code and it failed meaning despite the program counter claiming rows were inserted in fact they were not.
Dec 07, 2007 | Computers & Internet
Microsoft SQL Server 2000 Standard Edition for PC Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
