Sub woofer hum sub333 - Audio Players & Recorders
Hum is caused by shielded audio cable positioned too close to mains transformer. Open rear side panels and locate twin grey shielded cables from second amplifier board going to little printed circuit board screwed to the back of the plastic box that covers all I/O connectors. Just reroute this cable so it has more distance to the transformer and the hum will be gone!
Posted on Jun 01, 2009
Humming sound on off mod
do you have active speakers eg sub woofers powered speakers.they will still make noise if the power is left on. turn off power to sub woofers etc
Apr 08, 2014 | Audio Players & Recorders
My Velodyne DPS-10 subwoofer hums when you plug in the RCA cable. The hum increases in volume when you touch the rear metal panel.
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
Jul 17, 2011 | Velodyne DPS-10 Subwoofer
Powered subwoofer has hum
First of all confirm if the hum is an internal or external problem.
Disconnect the RCA sub woofer input from the back of the unit and turn it on. If there is no hum it could be the interconnecting cable or the output from the receiver. But in the stand alone mode if the sub woofer hums when powered on you have internal problem and will have to be looked into by a professional.
Many a time the earth or the shield of the interconnecting cable is the culprit, because the sub sits on the floor and you might shift it for cleaning the floor and the cable can stretch and snap internally.
Apr 01, 2011 | JBL SCS145.5 System
No sound comingout now on my HT BD2T subwoofer,just humming.
Try reconnecting; then replacing the audio cable for the sub woofer. I think it is just a standard RCA cable.
When you disconnect the RCA cable does the sub woofer still hum? If so the sub woofer may be bad. If it falls silent chances are it's just the cable.
Mar 08, 2011 | Samsung Audio Players & Recorders
I have no output from subwoofer
Hello Fixya customer,
Thank you for your question.
Please check that the sub woofer and RCA cable are working by removing the RCA wire from the Sub woofer output of the Onkyou and touching the center terminal of the RCA plug. You should here a hum when it is touched.
If you get the hum, then the next step is to "Clear" the Onkyo by holding down the "VCR and Stby" button until you see "Clear" on the display. Warning, this will clear any settings special that you have made to the receiver, but will get you back to the Factory settings.
Lastly, check various sound fields, and the Sub woofer volume setting, if you still do not get sound, please have a Onlyo service center verify the output.
Thank you using Fixya.
Apr 28, 2010 | Onkyo TX-SR606 Receiver
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Humming noise when woofer turned on
check the NPN and PNP transistor output maybe shorted.....
Jul 07, 2009 | PSB Image Sub Sonic 6i Subwoofer
I bought a sub woofer from a thrift store used and even though my existng computer speakers have a sub woofer jack, after hooking it up, it doesnt play. I bought the digital chord which fits well in the...
Different sound system use different voltages for their speakers. Look up in your computer manual what the electricial requirments are for the speakers and see if the one you bought matches.
Dec 15, 2008 | Computers & Internet
Sub woofer has a hum
I have found that with other appliances running, or a busy circuit, I have the same problem. Try to turn everything else in the house off and check again....A/C are often culprits. You can buy a line isolator for the plug, although they are just more money to spend. If this doesn't work, well, it could be a crappy home theaater receiver. It happens
Aug 08, 2008 | Audio Players & Recorders
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
65 people viewed this question
 Grubhead
Grubhead
