1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
