Question about Toshiba e-Studio 161 Copier Copier
When i on copier it display H-4 I do not understand the part "Main code Start key Sub code Start key"
Hi
can you help me with the same problem?
i do not understand the part "Main code Start key Sub code Start key"
thanks in advance
    Problem Solver:
  • 3 Answers
Press alternatively Contrast mode Key(Auto/Text/Photo) and cancel "c" Key to enter service mode, while entering into service mode everything goes off, then press 14 and print(start) then turn the power off and back on. if u still have the same problume check the heater lamp and thermister(H2 problum is related with low temperature)
Posted on Feb 06, 2009
How do i remove or cancel error message h4 on sharp digital ar-153e copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Oct 23, 2015 | Sharp Office Equipment & Supplies
How do clear H4 error code on Sharp Copier arm256
OR
Aug 02, 2015 | Sharp Office Equipment & Supplies
HOW DO I RESOLVE H - 4 ERROR ON MY AR-5320E SHARP PHOTOCOPYING MACHINE?
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Apr 30, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
Mar 20, 2015 | Sharp Office Equipment & Supplies
Error h4 on sharp at m318 copier
OR
Mar 16, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
How do i rectify error code h4-01?
first you have to enter simulation mode:
#/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
main code is 14, sub code is 0 in your case.
H4-01 means Sub heater lamp abnormally low temperature detection.
You may also have a dirty/defective thermistor in the fuser unit.
Oct 29, 2010 | Sharp AR-M237 Digital Copier
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
When I switch on the copier display H and than 4.. please solve my problem with thanks.
"C" key AUTO/TEXT/PHOTO key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
If the machine dies enter code 14 then press start, the machine will reboot normal, if the problem persist, the fuser unit needs replacement
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba estudio 161 copier
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
Toshiba e-Studio 161 Copier Copier Logo
64 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
