Question about M-Audio Audiophile 192 Sound Card
M-Audio 192 Sound Card _ No Sound comming out
I have a problem with my Sound card, I have recently changed my mother borad in my computer and now for some reason no sound is comming out if my speekers i have installed all the drivers again and it seemd to be running fine?
Here where it gets tricky, when i go in to my sound set up on the 192 sound card I can see the that sound is going to the card from the computer but there is nothing comming out of my monitors?
Can any ony help me with this?
  • Anonymous Feb 23, 2009
    I have the same problem. I can't figure it out, i've tried the outputs for audio stereo speakers and headphones... the sound is like "I want more sound" it seems that something that obstructs the full range of signal, like a not-fully-connected with interferrence. Is not my cable, is not my operating system, nor my speakers. What can it be ? Thanks for future response and solutions.
I was speaking to this custom pc company about my identical problem. Turned out that I had the wrong speaker setting in Windows. It was set to 2.0 when it should have been 5.1 and hey bingo, it worked. Not sure if thats what your problem is but sounds the same. Ted
Posted on Apr 27, 2009
I've got the same problem myself- too quiet output. Software and drivers look fine; I even tried using a turntable-preamp and it amplified it, but the sound was very bassy and muddy... Can't figure it out. Windows XP. I'd appreciate it if anyone can share their experience and any solution/resolution
Posted on Jun 25, 2010
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
Sep 16, 2011 | M-Audio Audiophile 192 Sound Card
My computer is no sound
At first you just load your sound card driver, install it. After installation you must restart your computer and you get sound.
May 08, 2011 | M-Audio Audiophile 192 Sound Card
I dont know hwta is the model of my sound card and i cannot activate it after i formated my computer! my mother borad is ASUS P5S800-VM , can anybody help me to find the sound card activate download?
ASUS P5S800-VM Drivers
Please visit the above link from ASUS Official Support. Select the OS (Operating System) e.g.Windows XP and download the required Audio Drivers. Extract the 'Zip/ Compressed file' Double-click the setup exe file and follow the on-screen instructions to install the drivers
Hope it helps! Good Luck!
CreativeTECH
Feb 25, 2011 | Computers & Internet
Installation of audiophile 192
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
Dec 02, 2009 | M-Audio Audiophile 192 Sound Card
Cannot activate my sound card
You have to install the driver of your sound card. If it is no with you , you can download it from the net by giving the model of your sound card.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 03, 2009 | Computers & Internet
Cannot render audio capture stream
On the "Audio Settings" in the Life View software, at the "Audio Input Source" on the drop down arrow, select "None". This settings will use the internal PCI Bus for listening and recording TV. The audio loop back cable in this case is not needed anymore.
Dec 06, 2008 | LifeView FlyVideo 2000 / FM (701013821030)...
Sound card
This this the guide website for HP computers contains the instructions needed to install a sound card
and also why I wanted to know the HP model of SKU model of the computer....
Just keep me posted if you still have problems.
Aug 20, 2008 | Intel Premier Resources 4-Channel 32-Bit...
SOUND CARD
Hi
If u have old sound card integrert in you'r mother board DESALBE it in BIOS,then try to install driver for new sound card..If you still have a problem with driver or sound card contact me  :
ar_pllana@hotmail.com
OR HERE!
Oct 08, 2007 | Microsoft Office Outlook 2003 for PC
M-Audio Audiophile 192 Sound Card Logo
468 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
