Question about Microsoft Windows Server Standard 2003 for PC
IIS is not shown in add or remove programe
i wnat to install the IIS in my system, but its not shown in add or remove programe. please send the dolution, how can i install the IIS in my system?
Waiting for your reply...
Regards,
Sannjeet
    Champion:
  • 214 Answers
Hi, there
in the add/remove select SELECT ADD/REMOVE WINDOWS COMPONENTS
there you check the INTERNET INFORMATION SERVICES(IIS)
put the windows cd in the drive and go next
thank you
Posted on Aug 21, 2008
SOURCE:
How to remove
go to control panel click add or remove program and select your software and click uninstall
You can use ccleaner to fast uninstall of software,its can be use to uninstall software,clean registery and many more features
May 13, 2013 | Computers & Internet
Scan won't send the files to the network folder
1 - If connecting via the IP adress, please check that the IP address for the destination's folder hasn't changed (if it is an automatic ip address, i'll recomment placing a fixed one,
2 - Check the folder's permissions, you can try to allow anyone for that folder, write and execute for all users.
3 - If you transfer files via the FTP protocol, then you should enable file sharing with the ftp service active (port 21):
Thias is what i have found for windows xp:
"XP includes a built-in FTP service component that lets FTP clients connect to the machine and read or write files; however, this service doesn't install by default. To install the FTP service, perform the following steps:
- Start the Control Panel Add/Remove Programs applet (go to Start, Control Panel, then click Add/Remove Programs).
- Select Add/Remove Windows Components.
- Select Internet Information Services (IIS), then click Details.
- Select the File Transfer Protocol (FTP) Service check box, then click OK.
- Click OK to close all dialog boxes."
hope these things help
Dec 19, 2010 | Toshiba e-STUDIO 4511 Printer
HOW installIIS
Click on Start, Settings, Control Panel. Choose Add or Remove Programs. Choose the button on the left Add/Remove Windows Components. IIS is the 4th or 5th item down, depending on your Operating System.
Nov 10, 2009 | Symantec Endpoint Protection 11.0 ??? 5...
Computer
2 ways
1.start - settings - control panel - add remove programs - click on add /remove windows components - click on checkbox front of IIS click next (you mus have the windows xp cd)
2. or you can download from microsoft (must be genuine windows)
Jul 08, 2009 | Microsoft Windows Vista Ultimate Edition
System suddenly gone slow
Download and run malwarebytes which is available at www.download.com
Mar 29, 2009 | Microsoft Windows XP Professional With...
Please help
First check to see if you have an IIS connection. To do this you must go to start menu>add or remove programs>add/remove windows components>internet information services (IIS). If its not checked then check mark the box and press next. Another might be that its working offline which is located in the tools menu. If you can get the hp site for compaq then download the network driver into a flash drive or cd then your in luck because you can install it in the compaq. Here's a link hope it helps good luck http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=93214&lang=en
Sep 14, 2008 | Compaq Presario 5000 PC Desktop
How to configure FTP server in windows xp prof ?
Setting up an FTP site Using Windows XP Professional Windows XP professional (as well as Windows 2000) includes Microsoft's IIS (Internet Information Server) which can be used to create an FTP site on your computer. It's a fair bit less complicated and less flexible than using some third-party FTP server software packages, so we will give you guides for setting up both. If you are using XP Home you will need to use third-party software. There is no way to publish an FTP site with the Home Edition of XP.
The first step is to check that IIS (Internet Information Services, Microsoft's web-server application) is configured properly.
Go to start\'control panel'\'add/remove programs'\ choose the 'add/remove windows components' button from the bar on the left. Highlight the item 'Internet information services (IIS)' If it is unchecked, check it, then click 'details.'
The components you will need are: 'common files,' 'file transfer protocol (FTP) service' and 'internet information services snap-in.' Uncheck any others then click next. IIS will configure itself, and you may be prompted for the XP CD.
Mar 21, 2008 | Microsoft Windows XP Professional x64...
Ftp
Do you have IIS installed on your xp machine? If not , go to add/remove programs, click add /remove windows components, and select Internet Information Service, and click apply/ok. You may be asked for your XP disk , if so, insert the disk into the drive requested to procede. Once IIS is installed on the machine, Set the router up for port forwarding on ports 24, and 25.
Nov 30, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Microsoft Windows Server Standard 2003 for PC Logo
103 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
