Question about Microwave Ovens
The light on the picture of a lock is on. Nothing will work. What is the problem.
  • 600 Answers
Hello, Thank You for using FixYa. I will be helping you today.If you have a lock button hold it until it unlocks.
Thank You and please rate my answer if it was helpful..
Posted on Jun 19, 2011
SOURCE:
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
My microwave reads loc and nothing works
This is from the 1100ST manual:
CHILD SAFETY LOCK
The safety lock prevents unwanted oven operation such as by small children.
To set, press and hold STOP/CLEAR for 3 seconds, LOCK indicator lights.
To cancel, press and hold STOP/CLEAR for 3 seconds, LOCK indicator goes off.
Kelly
Mar 15, 2011 | Magic Chef Microwave Ovens
The "ON' light keeps flashing, which I have never seen before, and nothing will happen. Tried unplugging, readjusting on the lock position- but nothing works. Still pretty new, maybe used like 20 time,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Microwave Ovens
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Galanz Microwave problem
its more likely to be a fuse from the transformer to the cap or the diode.
Sep 14, 2009 | Microwave Ovens
Kenmore Microwave 62622 display says "locked" and will not operate
hold your finger on the locked button till the light goes out
Jul 04, 2008 | Kenmore 62622 Microwave Oven
Will not restart or respond to reset clocks or lights wont work nothing works what should we do
Don't do nothing at all??
If nothing works or no lights come on, try to change the outlet if not working replace the fuse of the MW
May 11, 2008 | Microwave Ovens
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
