Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
160gb samsung sata II
Does not boot into windows (XP), ABSENT in the CMOS.
    Problem Solver:
  • 29 Answers
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
rmatheson@wowway.com
Posted on Sep 30, 2008
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Have installed two new SATA HDD's, but don't show up in CMOS
Just a tip: Your OS shouldn't be on RAID. RAID is for storage.
If it is a software RAID you will need to load drivers
Even if they are disabled in boot configuration, it will show them as being attacked. You should have two areas in your BIOS/CMOS for configuring & enabling, along with setting order of boot.
Apr 15, 2010 | Vision Computer VisionMan Pentium D 830...
HDD problemon asus motherboard p5rd1-vm
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
Dec 11, 2009 | ASUS P5RD1-VM Motherboard
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Can samsung q20 upgrade to 160gb hdd
As long as you buy a notebook hdd [2.5 inch] with the right connection for your computer. ide. sata, sata II, depending on what your computer specs support, size doesn't matter in regards to storage space. Hope this helps.
Apr 03, 2009 | Samsung Q20 TXC 1200 (NQ20RP3PHG/SUK) PC...
Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Dec 11, 2008 | Mercury P4VM800M7 Motherboard
Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Open Questions:
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
262 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
