Question about EliteGroup P4VMM2 Motherboard
P4VMM2 MOTHERBOARD AT FIRST IT WAS OK BUT WHEN I RESTART THE FUN WAS ONLY THE ONE RUNNING NO BEEP NO IMAGE ON THE MONITOR NO ACTIVITY AT ALL PLEASE HELP , THANKS
Thanks for the reply but i have done what you've said yet i replace the power supply from another p4 which was in good condition but the problem is still the same thanks for the response i appreciate it fully
Posted on Aug 21, 2008
  • 3,051 Answers
Have u checked your power supply by unplugging it from the mother board and prressing the power key wait 15 bseconds and then reinstalling the power supply to the mopther board and then power everything up and reboot
  • Michael Thomas
    Michael Thomas Feb 17, 2009
    hi there again
    you may also want to disconnect the cables and power to the hard drive and the cd rom and try to boot and see what happnes you may have a cable that is not in the right if it starts up than you know one of your cables were not hooked up right
My Toshiba X200 doesn't show any image.I've bought a new motherboard, but still no image appears.The tech that told that the problem was with the motherboard (that was supposed to be burned).Now he tells...
enable what? BIPS? never heard of it in the last 10 years, are you sure you are dealing with a PC tech there?!
Have you tested that the RAM on the computer IS OK?
Have you tested that the Video card on the machine is OK?
has any real troubleshooting been done on the machine?
if he just told you the motherboard was burned without doing any other testing you are dealing with a fraud.
Nov 07, 2010 | Computers & Internet
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
3 long beep award bios after change of resolution
not yet, don't buy anything yet.
restart your pc and after the pc does the memory check press the F8 button repeatedly.
you will get a list , choose vga mode.
once in vga mode, choose 800X600, close the setting page
restart your PC normally, your problem is solved.
Mar 24, 2009 | EliteGroup P4VMM2 Motherboard
Memory Upgrade - from 256DDR1 to 1GB DDR1
sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
No image input and pc makes weird sounds on start up
Remove & reinstall all the memory sticks (reseat). If that did not fix the problem, remove all the memory sticks and reinstall them one at a time to test them in an effort to determine if one of them has gone bad. Use this same methodology to test all of your device cards.
Check to make sure the CPU fan wire is connected to the fan header on the motherboard and that the fan is operational. Most motherboards (especially AMD) require the CPU fan to be operational and connected to the motherboard to avoid frying the CPU. However, this requirement can be disabled in the bios to accomodate CPU fans that do not run off of the motherboard fan header.
Can you get into the bios? If so, I would suspect the CPU and memory are ok. Does the clock have the right time? If the time on the clock is wrong it could indicate your bios settings are not being maintained after you power down and you may need a new CMOS battery.
Usually a beeping motherboard is an indication of a hardware issue. The data on your hard drive is probably intact. If you need to retrieve some files from the drive for your graduation, you can always install the hard drive into a USB external hard drive enclosure and connect it to an oprational computer.
Hope this helps - good luck!
Nov 01, 2008 | Computers & Internet
VIDeo CARD not working
You will need drivers for the FX5000 first, disable the driver for the one your using, shut down and then install the new FX5000, boot up and wait until the VGA comes on, it can take several mins sometimes.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
BEEPS
just reseat the memory modules it will fix the issue
Jun 07, 2008 | EliteGroup P4VMM2 Motherboard
Pc won't display but it switch on
8short Display memory read/write error The system video adapter is missing or defective
1 if it is an AGP card could be the slot for it is defective
2 Disable the onboard video chip in the bios try it again
3 If you have an old PCI videocard try that
4 if ou have 2 slots of ram chips try without one in then take it out and try the other
Feb 25, 2008 | EliteGroup P4VMM2 Motherboard
Please help me with my p4vmm2 motherboard
power off, then open case and find reset jumper on mobo, then actuate reset then return reset position then power up...any changes?
Jul 04, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
51 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
