Question about Jura Capresso Impressa F9 Espresso Machine
Jura capresso f9
I have a f9 and am having a problem....every time i turn to machine on, it is telling me to fill the water portion (i push the button, it makes the noise but no water comes out). this time, right before this occurred, i had installed a new water filter specifically to their instructions... some water came out of the steamer but now nothing and i can't get it to clear..
any ideas (besides sending it to repair since i brought it overseas with me to Micronesia) please????
  • frijoli Sep 14, 2008
    My machine has never been used but is one year old. Filter is NOT installed. Machine will not fill! Always says"fill system water portion".
  • Anonymous Jan 28, 2009
    I have the same problem, No water, no steam, new filter... Just said Fill System.
    Can anyone tell me what the fix is, and what tools are required.
    Thanks
I had the same problem, it told me to fill the water portion but when I pushed the button it would not clear. I called customer service and spoke with a technician. He told me to turn off and unplug the machine,remove the grounds drawer and reach inside the machine behind the plastic chute that hangs down in the middle. There is a metal disk mounted on an angle with a raised dimple in the center. The disk is the size of the discarded grounds wafers. The dimple in the middle is a sensor. Some times the accumulation of oils, coffee grounds and water leaves a residue on the disk that can short out the sensor. After locating the sensor and memorizing its position reach in with a paper towel and wipe off the residue. It works best to use a dampened towel and the a dry one. You will remove a substantial film of residue from the disk. I have done this numerous times and it has never failed to work. p.s The technician also advised me that the problem is more likely if you have your grind set too fine.
Posted on Jul 10, 2010
On my machine, I found a plugged fitting on the steam vavle. You do have to remove the side covers to service this. I removed the valve(make sure the power is UNPLUGGED), and took off the metal fittiona and found green corrosion(brass or copper). i unplugged the fitting with a needle. Put it back together and descaled the machine. Works well now.
Clay
Posted on Dec 27, 2008
I called customer service and spoke with a technician. Was told to remove the filter (place it in bowl of water so it won't dry out) and then press the steam button and wait for it to cycle. Repeat this procedure for up to 15 minutes. When water actually starts coming out, replace filter and you're good to go. For me it took about 8 cycles before water flowed and error message disappeared.
Was also advised to wipe down the recess where water container sits to remove any calcium.
If that doesn't work she said to unplug the machine and let it sit for an hour, and then plug in and try again.
For me, continuing to hit the steam button did the trick...hope this helps!
Posted on Nov 05, 2010
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
FILL SYSTEM WATER PORTION.
sensor is broken or damaged. look for it, or ask a professional repair office.
May 03, 2015 | Jura Capresso Impressa F9 Espresso Machine
I have a 5 year old Jura Capresso F9. It has given me Malfunction 8 a number of times over last few months, but have always gotten past it. The other night, the machine was off but plugged in. It came...
This could be a problem with the main control board or CPU. It could be that there is moisture after getting onto it and causing the fault which may only need to be dried off. Otherwise the machine may need a new board. If main board is 5 years old, its probably had its day.
Mar 29, 2011 | Jura Capresso Impressa F9 Espresso Machine
Fill system....water portion (error message)
It means that you need to fill up the system, inside the machine. Push the Water portion button, then it should flow water from the watertube. If you`re having trouble with this, change the water in the tank with luke warm water, this usually solves the problem after a few attempts.
If nothing happens and no water comes out, the solenoid valve is defective and must be changed.
Oct 03, 2009 | Jura Capresso Impressa F9 Espresso Machine
My Jura Capresso coffee maker is "shorting" the coffee, delivering espresso-sized portions instead of larger volume coffee. The electronics seem to be malfunctioning.
The sieve in the brew unit is probably clogged, this means that it takes to long to push the water through the coffee. There is an automatic time-out on the pump that controls this. It also can be that your coffeeoutlet is clogged.
Try cleaning out any used coffeegrounds from the inside of the machine, use your finger up into the brew unit. If this doesn`t help, it needs service.
Sep 13, 2009 | Jura Capresso Impressa F9 Espresso Machine
Fill water portion... same freaking thing! F9 Impressa
Where is the water supplycoming from? When you press and see it saying "filling" it should be fillingon its own. Giving it enough time to fill it senses the reservoir is still empty and asks you again to fill it up. it's saying it can't do anything until the reservoir has water in it.. Make sure the water supply line is not kinked or restricted. When you press start, a valve is opened long enough to provide the water needed to start the brewing proces. Right? Let me know what you find.
Aug 27, 2009 | Jura Capresso Impressa F9 Espresso Machine
Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
Apr 11, 2009 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso Impressa F9 Espresso Machine Logo
1,041 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
