Question about Philips 50P8341 50" Rear Projection Television
Philips 50P8341 50 in
could you please tell me where are the vertical output IC and if they the same as the coverange ic
  • Philips Master
  • 8,617 Answers
Board location 7550 on the LSB ( Large board on the right) Its a TDA4861 its not like the convergence IC its mounted to a black aluminum heat sink with a metal spring clip
Posted on Aug 21, 2008
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
My PHILIPS Matchline TV - 29SX8776 having vertical output problem. Please help, I need the service manual . many thanks .
Check the vertical out put IC circuits. Go by IC number and search in Google. You will get a application circuit. From that you can make out.
Check the PCB copper tracks. Some times its get oxidized and opens.If found open join the ends, with a insulated wire ( end to end).
Also search typing service manual Philips T V model No. in Google. For some models service manuals are not available. Search by IC part no. will be faster.
Aug 19, 2010 | Philips Televison & Video
Screen went black
Possible vertical output IC failure, which will cause the Picture tubes to shutdown but audio will still function. Try replaceing the vertical IC
Jul 15, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips 9p6044. where can I buy convergence ic's and a
its far more likely that you need a new Vertical output IC. The convergence ICs wouldnt prevent the picture. When you have audio but no video it is often meaning vertical failure. Try replaceing the vertical IC
Apr 23, 2009 | Televison & Video
No picture???
You have defective Vertical output IC, Replaced the Vertical IC that is defective.
Dec 04, 2008 | Philips Magnavox TS3260C 32" TV
Philips 50P8341 green light
I believe its the vertical output IC. Diodes would tend to blow fuses . I would replace the vertical output and see if that takes care of the problem.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
Hello again!!!! model# is FP5251 G105
There should be three circuit boards on that model a small board on the right then a larger board in the middle and another large board on the left the vertical IC will be located on the middle board it will be attached to a aluminum heat sink.
Jun 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sound no picture
sounds like cold solder at the vertical output IC. Try resoldering the vertical output IC and see if that helps.
Mar 29, 2008 | Philips 55PW9363 55" Rear Projection...
64p8342 Powers up,but no picture.
Try resoldering the vertical output IC have seen many of this model have hairline cracks on the vertical IC solder joints causing blanking of the CRTs while audio still worked.
Mar 13, 2008 | Philips 60P8342 60" Rear Projection...
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Philips 50P8341 50" Rear Projection Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
