Question about Kodak Office Equipment & Supplies
Printer keeps on asking to lod ink cartridge and it already in.
  • 48 Answers
Open the main panel in front..let cartridges settle to middle, remove, and inspect, then replace..gently..
Also, more printer resources are here
Posted on Aug 21, 2008
My printer is not HP it is Brother MFC-260C
The printer uses several ways to show ink levels. When you replace the cartridge it askes if it has been replaced, Say yes and it sets the ink level monitor to full. As the cartridge empties it them checks through an electronic eye system through the cartridge. When it cannot see any ink it says it is empty.
Replace the cartridges and it should fix the problem.
Feb 22, 2016 | Brother MFC-260C All-In-One InkJet Printer
Why does it keep asking to replace black ink when already a new one has been put in
Did you use genuine ink cartridges or no-name ones? Some non-genuine cartridges just will not work no matter what the seller tells you.
If you were using genuine Epson cartridges, have a careful read here, especially the steps at the end of the article:
http://www.inkbank.com.au/webcontent31.htm
Feb 09, 2015 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Wrong cartridge : i m asked to replace the with the original ink cartridge that was shipped together when first purhase the printer. The problem is they were already thrown away after used. my...
The printer is asking for the original type of cartridge HP 02 assuming the current cartridge is a different type.
These instructions may also help:
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
May 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
The printer keep asking for ink replacement. the cartridge ink is half full. how can i use the remaining ink if the printer wants to replace a new ink. plz help
You take on the cartridge and you get the cartridge into the printer to put a mid-trough, where they see the chicken trough of ink cartridges.In the middle of the cartridge put tape and the printer see the cartridge full and you can use the remaining ink.If i have been useful please give me a vote :).Thanks
Apr 13, 2011 | Brother MFC 240C All-In-One InkJet Printer
My printer keeps saying to install a ink cartiage but there is one already in there.
Solution 1. you need to remove and return tightly the ink cartridge.
Solution 2. maybe you purchase ink cartridge that are not compatible with the printer.
Solution 3. if you are only refilling the ink cartridge, maybe it is worn out and the printer is no longer detecting the cartridge due to wear and tear.
Nov 26, 2010 | Dell Office Equipment & Supplies
Keeps asking for ink and it has ink
Try removing, and then reseating the MAGENTA cartridge.
If you replace the MAGENTA toner-cartridge, does the problem go away?
Jul 30, 2010 | Xerox Phaser 8560DN Laser Printer
Brother Printer - Keep complaining about No Ink
Hello.
From Brother support:
"The message #NO CARTRIDGE# may appear if one or more of the
cartridges are not properly installed or an ink cartridge is
defective,such as air bubbles, or empty. Verify all the cartridges are
installed correctly and they are not empty or defective by following
the steps listed below:
NOTE: Cartridges that have already been installed are no longer
vacuum-sealed; it is very important that the cartridge remains upright.
If the cartridge is removed and placed on its side, air may be
introduced into the ink supply tubes, requiring repeated cleaning
before print quality is restored.
a. Lift the top cover to the open position until it locks securely
into place.
b. Then, remove all ink cartridges by pulling the white plastic hook
toward you and pulling the cartridges up and out of the machine.
c. Because all the ink cartridges have been removed, the LCD will
prompt you to install each color cartridge.
d. Important!! Reinstall the ink cartridge(s) in the order of the LCD
is instructing you too. Press down FIRMLY on the top of the cartridge
until it is fully seated. Push the white plastic hook towards the
cartridge to verify it is fully latched over the top edge of the
cartridge.
e. Close the top cover. The LCD will ask you if you have changed the
cartridge to new. Press 1 for yes and 2 for no. Press 1 for yes for
each color. The LCD will alternately show CLEANING and PLEASE WAIT. When the Brother machine completes the cleaning cycle, the LCD returns to Standby mode.
Hope this helps.
Dec 10, 2009 | Brother MFC 210C All-In-One InkJet Printer
My printer wont accept my coloured ink cartridge
Is it the new original cartrigde colour or not ? If yes, you should ask a guarantee from the seller.
There is a chip inside the cartridge, sometimes it doesn't compatible for the printer software to read the chip.
The printer will keep asking for the new one if there is no ink in the cartridge.
Sep 06, 2009 | Lexmark X2650 All-In-One InkJet Printer
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
