Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hand held hose won't spray
From the day i bought it it has never worked. i've had it a couple of years now. I didn't use the hand hose right away, it was more than a month later. so i couldn't take it back to the store because time had run out for a return. Nearest service center is 50 plus miles away so i never got it in for warranty, (Ramble, ramble). Any way i tore into it and got it apart by dumb luck. I found a switch inside that turns on the water pump, it presurized the line, but i can find no way to get that to happen with all the parts in place and not jamming something in there to have the switch on all the time. What might i be missing? i can't find anything that would cause that switch to come on. even a schematic would be nice but i cant find one aanywhere. thanks for your time
  • daffy2000 Sep 02, 2008
    they are so small i can't see anything, blowing them up makes them fuzzy
    President:
  • 1,673 Answers
Hard to determine without seeing it, maybe these drawings will help:
Posted on Sep 01, 2008
  • Lauren Junge
    Lauren Junge Sep 02, 2008
    what is your email addy, I can send the drawings that way and will be larger.
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
Bissellproheat shampooer hand held sprayer doesent sprey water
Hose is clogged , try cleaning it with something
Aug 15, 2009 | Vacuums
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
No spray in hands-free mode.
Hi, I had the same problem ... I tried hot water for 30 minutes with no sucess ... then opened the unit and could see nothing real obvious in the solution hoses ... so took the main hose off the valve from the solution tank ... then plugged in the unit over a towel (be careful) ... and selected clean ... the valve opened and a bunch of fluid flushed through - so I knew the valve was ok. I then blew through the remaining hoses and did seem to get some flow .... and reassembeled the unit ... and filled the tank with vinegar solution ... the manual spray immediately cleared with a bunch of dark flakes ... the regular brush spray worked fine.
Sep 11, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
64 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
