Question about Sun FIRE 28 (Refurbished) (SUNFIRE280R) Motherboard
Hard disk can be repear?
Installing operating system cannot procced, but hard disk is detected.
    Master:
  • 763 Answers
Did you try to check your cd or dvd rom if its detected too? does the disc you put is readable and bootable? what OS are you installing? ask me again if anything happen.
CHARCOIS
Posted on Aug 21, 2008
Emachines screen says no bootable device insert boot disk. I have no boot disk
This error indicates that the system is not able to find a boot-able device to load the Operating System. It could be something as simple as a disconnected hard drive, or it could even be a corrupt hard drive.
You can check if the hard disk is being detected in the BIOS. The key to enter BIOS in E-machines systems are Tab, Del or F2.
If the hard disk is being detected in the BIOS, it could be a faulty hard disk. You can try booting from the recovery partition by pressing Alt+F10 when starting up the computer. If you're able to get into the Recovery Partition, you can try a recovery, but you might lose all your data. If you're not even able to get into the Recovery Partition, you'll need to get the Windows disc for installing the Operating System again.
You can refer to these links for further information:
http://h30434.www3.hp.com/t5/Notebook-Operating-Systems-and-Software/No-bootable-device-insert-boot-disc-and-press-any-key-error/td-p/151244/page/3
http://superuser.com/questions/119307/how-do-i-boot-to-the-recovery-partition-on-an-emachines-d620-notebook
GuruAid
May 05, 2014 | Computers & Internet
No operating system found
it mean your operating system is corrupted or your hard disk is not detected with machine
for operating system re install your operating system and if you face any trouble to installing operating system like hard disk not found or no drive.
so go to setup and check that if there showing any hard drive.
absoultly not so plug your data cable and power cable properly on your hard disk and re check now if problem is not solve yet. so now pull out your hard disk from pc and plug the both wire of power and data and now check that your hard disk is running making some noise you can feel that its running if not so replace your hard disk card and now plug it on pc it will running now and install your operating system . you can operate your pc with your old data. thanks
Jul 16, 2011 | E-Machines T1855 PC Desktop
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
Booting
When it come to deleting partitions or adding partitions I suggest you download WD's Data Lifeguard Tools. WD's User manual;
http://www.wdc.com/en/library/other/2779-001005.pdf
The object is to setup you're partitions in DOS mode by creating either a bootable CD or a bootable floppy disk. Using windows is not always the best way.
Same for you're Samsung drive, ES-Tool;
http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
Once completed installing you're operating system should be simple. Be sure to check the boot order in you're bios before loading you're OS.
Mike
Jun 06, 2010 | Asrock ConRoeXFire-eSATA2...
When i install the xp operating system after
There is problem with your hard disk. Is there any noise in the hard disk.
you should change your hard disk.
Mar 15, 2010 | Toshiba Computers & Internet
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
Apr 14, 2009 | HP Pavilion 520c PC Desktop
Hard Disk Drive not detected
when installing a new hard drive, there is nothing for the bios to read to run the operating system
go to the bios , boot section and change the boot sequence to boot from cd first
then restart the computer and reinstall the operating system disc in that cd when the computer is up and running change the bios back to hdd as first boot selection
May 07, 2017 | Sprint Hitachi P300 Cellular Phone
Formatting hard disk cannot procced
make sure that the wires are correctly inserted. see if in the first run will detect your hard disk. go on repeating the procedure until detects it. hope that helps!
CHARCOIS
Aug 20, 2008 | Sun FIRE 28 (Refurbished) (SUNFIRE280R)...
Sun FIRE 28 (Refurbished) (SUNFIRE280R) Motherboard Logo
56 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
