Question about Black & Decker B2300 Bread Machine
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down after years of service. help!!!!!!!!!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Posted on Jun 25, 2011
  • Bread Wizard
    Bread Wizard Jun 26, 2011
    Rating our advice will let us know if we are doing you any good. Please take a moment to rate this advice. Thank you. And for all your U.S. and Canadian breadmaker needs visithttp://www.bread-maker.net/sitemap.htm
SOURCE:
I press start and it just sits on prheat heat.
Many bread machines pre-heat on the whole wheat cycle. Give it up to 30 minutes and it should start mixing within that time frame.
Jan 13, 2013 | Cuisinart CBK-200 Bread Maker
HHH code, NOT a second loaf.
1- DELAY TIMER HAS A SWITCH FUNCTION THAT HAS FAILED. 2- WASH INSIDE OF BREAD MAKER WITH COLD WATER, DRY, AND TRY TO SET TIMER. 3- BREAD MAKERS ARE NOT AS POPULAR AS THEY USE TO BE, AND ARE AVAILABLE AT USED ITEM STORES FOR 15 TO 25 DOLLARS.
May 03, 2012 | Sunbeam 5891 Bread Maker
Where to purchase replacement Black and Decker bread maker paddle for model B2300 Thanks!
Replacement parts for your Black & Decker B2300 Bread Maker may be ordered online from the following site:
http://www.directpartsandproducts.com/bread-makers-b2300-c-1_96_115.html
Good luck. Thank you for using FixYa!
Aug 21, 2011 | Black & Decker Bread Machine
Dear expert: I bought a bread maker last Christmas season, model is B2300, I didn't open it until yesterday. After I read all instruction and put everything into the container, and trun on the power,...
If the sound you heard was a faint "clicking" sound that just means your machine was starting to warm up. Since you have no experience with bread machines yet you need to build up your confidence. Recommend you go to you tube and type in "how to bake bread in a bread machine" and watch some videos there to see how it is done. Don't give up on your machine! They are a lot of fun!
Mar 21, 2011 | Black & Decker B2300 Bread Machine
When you want to make only dough the dough senting does not work
The dough setting has a 20 minute delay before the paddles start to move. The manual say's "for most programs, there will be a 15-minute delay before mixing cycle begins"
Nov 07, 2009 | Black & Decker B2300 Bread Machine
My bread machine will not turn on. There is nothing wrong with the electrical outlet.
For the B&D All-in-one, on pg 12 it says "Press the 'start' button. For most programs, there will be a 15-minute delay before mixing cycle begins."
When I'm impatient, I use one of the cycles that does not have a delay (e.g. Rapid Bake 2
Oct 15, 2009 | Black & Decker B2300 Bread Machine
My bread maker does not turn on
There is a 15-30 min delay after the start button has been pressed.
Nov 01, 2008 | Black & Decker B2300 Bread Machine
Breadmaker Won't Start
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
Feb 09, 2008 | Black & Decker B2000 Bread Maker
Black & Decker B2300 Bread Machine Logo
542 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
nanisacan
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
