Question about Microwave Ovens
L am looking for spare parts on a Toshiba microwave Model no. ER 700A it is over 20 yrs old and l am missing some little tiny studs from inside the microwave, could you please tell me where l could get some Maria
  • 1 more comment
  • mmileto Aug 21, 2008
    They hold a panel inside the roof of the microwave, they are plastic, round and about 1/2cm in width, similar to a rivet that is the best way l can describe them.
    Thank you for taking the time in responding to my inquiry
    Maria
    Thank you for your help in trying to find the parts for my microwave. You have been very helpful. l think l will go to my favourite store...BUNNINGS!!
    Maria
  • William Miller
    William Miller May 11, 2010
    Toshiba stopped making microwaves many years ago, but some parts may be available.
    Can you describe in more detail what you mean by "studs"?
    Do they hold a cooking rack or a panel in place?
  • Microwave Ovens Master
  • 9,098 Answers
Yes, those are 1- or 2-piece nylon rivets. Sounds like they held the stirrer cover or waveguide cover on.
The original Toshiba part number was 325541052 but they are no longer available.
You can probably find suitable replacement nylon rivets at a local hardware or home improvement store if you take one with you or at least measure the diameter of the hole they need to go into.
I'd say they are about 1/8' to 3/16" if I remember correctly.
Or at the same stores you can get some nylon screws a little bit fatter than the hole and screw them into the holes. You will have to force them, but they will work.
Nylon is transparent to microwave energy.
Good luck.
Posted on Aug 21, 2008
  • William Miller
    William Miller Aug 21, 2008
Looking for part for stirrer on Toshiba microwave ER-800BTC
try ebay sounds like a spring clip or circlip.
Mar 27, 2016 | In Microwave Ovens
Need owners manual for Toshiba microwave model ER-9610-1
Go to the dealer where you bought it from...
and ask for a user manual..
they will definitely give you
Jun 06, 2012 | Microwave Ovens
Model #
Make and model will usually be on a label plate on the back of the unit.
With the age of the unit and unlikely availability of spares you may be better to look for a new unit. Cheers, Dan
May 08, 2012 | Microwave Ovens
Maytag 2 yrs old. Completely dead - like getting
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this wiring diagram at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
This model has TWO potential causes. The line fuse or the Thermal Cut-Out (Thermostat) for the Magnetron. The line fuse is connected in line with the power cord inside the unit and is listed as part of item 26 under the "Cabinet-Base-Cavity" heading.
The Magnetron Thermostat is listed as item 6 (part number 56001028) under the same heading. If you managed to overheat the oven any time recently, you may want to check the thermostat to see if it is still good. It should read 0 ohms when measured out of the circuit across the terminals.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
May 24, 2010 | Maytag MMC5000 Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Spare parts
go to appliance parts pro's website they're located in ohio
Aug 11, 2009 | Westpoint TV-258 Microwave Oven
Microwave oven replacement Model#MWF307Z-3 Allegro series
You can look for parts here on FixYa,
good luck hunting, I have the same prob, with my Sharp convection M/ wave. I have been looking for 3 yrs. now and it only a 1982. Good luck DFD
Apr 15, 2009 | Microwave Ovens
Whirlpool timemaster microwave removal
What caused the plastic metal rack holders to burn against the metal rack
Apr 06, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
